boost question?
Old Jul 8, 2011 | 07:33 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default boost question?
Hi all as some will know my turbo went on the focus so a call to vince at cr to discuss what i wanted and off with the turbo and he arrange collection. got it back tuesday got it fitted etc not really been out much apart from today and noticed it now only boost's to 1.3 bar?
The old turbo used to hit 2.0 bar and hold 1.8 bar now ive used the same actuator that was on the old turbo as i never sent it off with the turbo.
Anybody got any ideas as to why its lost loads of boost? ive spoke to vince earlier and he said actuator will need adjusting but surely that cant be the case? I presume its the actuator that sets the boost so the new turbo should run the boost actuator is set to previously.
Old Jul 8, 2011 | 08:21 PM
GribbiN's Avatar
GribbiN
Does the Autronic control the boost ? obviously not the same amount of pre load on it now.
Old Jul 8, 2011 | 08:54 PM
Dicko&Vacant
yeah mate its got a autronic boost control valve, so i take it all i need to do it adjust the actuator rod?
Old Jul 8, 2011 | 09:04 PM
pee vee's Avatar
pee vee
Is it a bigger turbo mate?
Might be wrong, but if it is a bigger/more efficient turbo, than the last one the actuator was used on, then the air pressure forcing the actuator open will be greater, so more preload would be needed?
I'm sure someone will have an answer, but that's how I'm thinking of it in my head LOL
Old Jul 8, 2011 | 09:27 PM
Dicko&Vacant
yes mate its gone from an aet gt29 whatever that was lol and vince had converted it to a gt30 spec.
Old Jul 8, 2011 | 09:47 PM
Rs1's Avatar
Rs1
Before you adjust the actuator bare in mind the 30 will be flowing more at the same or less pressure than the 29. If your not mapped for that extra flow the motor will lunch itself in relativly swift fashion.
Old Jul 9, 2011 | 08:10 AM
JamesH's Avatar
JamesH
If ouve changed to a different turbo you'll have to adjust the actuator accordingly! Get it all setup though
Old Jul 9, 2011 | 08:49 AM
jameswrx's Avatar
jameswrx
^ listen to this post. Bigger turbo is going to have less restriction, therefore the same pressure as before on a larger turbo = greater volume of air = need nore fuel. It's not just a case of running it to 1.8 bar as before to run the same.
Old Jul 9, 2011 | 08:59 AM
Danny.'s Avatar
Danny.
Get it down to Mark Shead mate, He'll get it running more than 2bar for you safely!
Old Jul 9, 2011 | 05:48 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
ill come for the run out if your going to sheadys lee
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
