jon@work
Old Jul 6, 2011 | 05:40 PM
cossie350's Avatar
cossie350
Default jon@work
Does anyone know if the god of cosworth ABS still uses the forum ?
I need his help
Old Jul 6, 2011 | 05:53 PM
Whats wrong fella. Ive done a few abs jobs on my saff before.
Old Jul 6, 2011 | 07:47 PM
cossie350's Avatar
cossie350
Hi mate, to cut a long story short, have a quick read of this :
https://passionford.com/forum/genera...e-problem.html
Basically i have blocked all the outlets on the master cylinder and the pedal is rock hard, so i know thats ok.
Which means the problem is in the ABS block ( the light is always on ), i have tried a new block but still get the same problem. I dont understand what is fucked or how it got that way.
I was hoping the jon@work fella could fire some tests at me to eliminate some of the parts.
Im thinking if i can get the light off the brakes will bleed .
Old Jul 6, 2011 | 08:56 PM
I hope this might help.Most of it is to check the sensors but there is a bit for the electro valves.
Old Jul 7, 2011 | 12:42 AM
cossie350's Avatar
cossie350
Cheers bud, your a legend, i will have a play tomorrow.
Old Jul 7, 2011 | 07:53 AM
Its only a bit of info but it might help. Check to see if your relays are ok and that you have lives and earths going to them. Have you replaced the other part of the abs system that sits on the passenger side of the engine bay. Ive got some wiring diagrams too if you need them.
Old Jul 7, 2011 | 09:17 AM
R4N SS's Avatar
R4N SS
check you fuse - i had someone buy my abs pump off me ages only to find their fuse had blown
Old Jul 7, 2011 | 09:49 AM
Karl 3dr's Avatar
Karl 3dr
Cheers Glenn, that info is very helpful to me as well as I've got a dodgy sensor
Old Jul 7, 2011 | 04:20 PM
cossie350's Avatar
cossie350
Quick update.
ABS light was on do to a dodgy connection on the drivers side front sensor, so cleaned the connector up and got rid of the light. All the other test were fine
Bled it for the 100th time and still no pedal
So only thing i could think of trying now was to put the old pads back in and try to bleed it with them in.
Stuck the front ones in, pumped the pedal a couple of times to push the pistons out and hey presto the pedal is right at the top and solid as fuck, didnt even need to bleed them.
Im absolutely done in and cant explain why the fuck any of the above has happened.
So looks like im going to have to get a couple of mm skimmed of my new pads before i can put them back in.
How bazaar !!!!!
Cheers for your help Glen, much appreciated
Old Jul 7, 2011 | 08:50 PM
Mad mate lol at least its all sorted.
I know when my abs light came on last time,i had a spare sensor and i plugged it into 3 of the sensor wires and the light didnt go out.I was that pissed off i thought well theres no point trying the osr one.
It was the osr one which was at fault lol.
The back sensors have a piece of alloy tube in the sensor so when you tighting it down it doesnt crack the sensor.This is what corrodes over time causing the sensors to crack then the water gets in the sensor and fooks them.
Old Jul 7, 2011 | 08:51 PM
Im happy to help fellow cosworth owners lol.
Old Jul 7, 2011 | 08:52 PM
Fuse theres 3 of the buggers lol.
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
frug
Wheels and Tyres
13
Aug 5, 2015 12:52 PM
