Escos oil query!
Escos oil query!
The oil gauge in an escos is it suppose to stay still? Ive just noticed today that when you are at idle in drops to the bottom(red) and then once you are on the move it goes up and stays about centre!!
Is this normal???
Is this normal???
should be on 4 bar + from cold start up
once warm, driving over 3000 rpm should be up to 4 bar
on idle an around 1-2
should NOT drop in to the red!
what oil are you using?
Sorry it is 5/40.
http://www.millersoils.net/index2.html
Click automotive oils and petrol engine menu.
Nah mate it will be fine.Have a look at wot the oilman on here says and he recommends around the same. But he doesn't do Millers and wont give a thumbs up or down about it.
Team HOTHOT!
lol - i use millers - was tempted by shell helix at one point, but heard some rumors about it been shite
the millers factory is just round the corner from me too - might see what discouns i can orgasmise
When using Mobil 1 motorsport, mine would just drop into the red at idle. Changed to Castrol RS and then to MOtul and when hot it's a couple of mm above the red.
Oil pressure is related to revs, so as these go up your oil pressure should go up to.
