help needed asap
Old Jun 18, 2011 | 12:55 PM
andy130's Avatar
andy130
Default help needed asap
i had the head of my tdi bora, refitted now it wont fire up?everything is connect i really need help fast
Old Jun 18, 2011 | 01:02 PM
dojj's Avatar
dojj
Resident Wrestling Legend
bleed the air out of the injectors
Old Jun 18, 2011 | 01:05 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Have you had any part of the fuel system open? Fuel filter off, injectors out etc.
If so, try keying on and off 20 times, don't try and fire it up, just literally key on until you hear the pump prime and then off again. This normally helps to purge any air from the fuel system. Then try firing up.
Old Jun 18, 2011 | 02:27 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
make sure the flap on the inlet is open. its part of the egr i think but looks like a throttle flap. cuts air to the engine when you turn ket off.
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
