help needed asap
Old Jun 16, 2011 | 08:51 PM
andy130's Avatar
andy130
Default help needed asap
does anyone know where the timing marks are on a tdi pd atd bora engine? havnt got the timing kit to hand, need pics of where the crank or fly wheel should line up, need help asap
Old Jun 16, 2011 | 08:53 PM
capriturbo's Avatar
capriturbo
Try http://uk-mkivs.net/forums/ too, I've always found them quite helpful.
Old Jun 16, 2011 | 08:55 PM
botters's Avatar
botters
competant bodger
the camshaft pins up into the head with roughly a 6mm drill bit and if you look on the crank pulley there is a mark on one of the teeth, if you look on the oil seal casing behind there is a round hole in it look to the left of that hole and the caing has a straight edge to it (you will see what i mean when you look) line the right hand edge of the tooth with the mark on up with that straight edge of the casing
i did one this morning so fresh in my mind lol
hope this makes sense without pics
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
