boot lock
Old Jun 16, 2011 | 04:58 PM
redrsrob's Avatar
redrsrob
Default boot lock
i have an escort rs mk 4 year 1988 the boot lock is stuck and i cant open it either on the key or with remote does anyone know how to remove/repair lock? thanks
Old Jun 16, 2011 | 06:28 PM
Is it a push button lock, or a turn only lock ?
If a push button long bit of 6x2 and whack/thump the lock hard, have to disassemble my boot lock about every 4-6 months on me sapphy as the grit from the garage roof slates jams it up, this is what I have to do.
Old Jun 16, 2011 | 06:40 PM
rst230bhp's Avatar
rst230bhp
try spraying WD40 in the lock, fixed mine this way
Old Jun 17, 2011 | 09:24 AM
redrsrob's Avatar
redrsrob
its a push button i will try a good hit on it, thankyou for replie i will let you know how i get on.
Old Jun 17, 2011 | 09:25 AM
redrsrob's Avatar
redrsrob
i will also try wd40 before i hit it. thanks for replie.
Old Jun 17, 2011 | 10:08 AM
RS500/364's Avatar
RS500/364
take it out and soak some silicon base spray
make sure the lock is upside down first and the other way so soaks though 90%
if u leave the lock in the car half the job !
My RS500 lock was not moving and locking the boot used the spray tf2 bike stuff did the trick
Old Jun 17, 2011 | 10:42 AM
GT85 is the best spray I've used.
Old Jun 17, 2011 | 05:51 PM
redrsrob's Avatar
redrsrob
thankyou this i will try first before other answers i had as this seems like a good option to clean it properly. thankyou for reply.
Old Jun 17, 2011 | 05:52 PM
redrsrob's Avatar
redrsrob
i will buy the spray tommorow. thankyou again for another answer to my problam. these cars should stay good and be seen on the road. thanks again.
Old Jun 17, 2011 | 08:13 PM
The problem I found with mine is no amount of wd40 or similar would help as lock was physically jammed as grit had got past seal ring.
I ended up after a few years taking the lock apart again to clean it out but this time replaced the internal seal in the housing holding the push button and replaced this with a felt seal, not had a problem since, that was around 2 years ago, prior to that I was doing the lock between 2 and 3 times a year, take out strip down clean out etc etc.
My mate pissed himself laughing as I carried a block of 6x2 around to open the lock, but carried it in the boot ha ha, what a numpty!!
Old Jun 18, 2011 | 09:22 AM
redrsrob's Avatar
redrsrob
the woods not much use in the boot lol. i am pulling mine apart today as i found an internal catch near the inside of the lock so i have to climb around my rollgage and feel for the internal release. thanks for all the info. rob.
Old Jun 18, 2011 | 03:40 PM
My same mate did worse, as I like to remind him, carried a fire extinguisher, under the bonnet!!
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
