L8 P8 differences
Old Jun 5, 2011 | 09:40 AM
lukeytheduke's Avatar
lukeytheduke
Default L8 P8 differences
hi folks, whats the difference between the two, sorry if its a stupid question but tried searching and nothing
Old Jun 5, 2011 | 10:33 AM
1374lee's Avatar
1374lee
The P8 you can run closed loop as standard,also has the facility to run a wasted spark set up,it already has the driver board installed in the P8 but you will still need ignition amp,leads etc obviously.P8 is a faster processing/moitoring ecu,cleverer than the L8 but P8 are renown to have problems from time to time.I'm no expert just what I have picked up on as I looked into running a P8 on my car,I have L8 at the moment.
Your best bet is speak to your tuner/mapper as a few top tuners would prefer to use the L8 set up.I hope this helps.
Thanks.Lee.
Old Jun 5, 2011 | 10:43 AM
lukeytheduke
cheers matey
Old Jun 5, 2011 | 01:42 PM
lukeytheduke
so u cant run wasted spark on standard 2wd ecu?
Old Jun 5, 2011 | 03:28 PM
whizzisat114's Avatar
whizzisat114
Yes you can run wasted spark with l1,l6 and l8.
Just need driver board ,coil pack, twin ign amps. ,loom and ht leads.
Msd do the lot with diy instructions for Ł400
Old Jun 5, 2011 | 04:00 PM
andy130's Avatar
andy130
iv gota p8 for sale if anyone needs one
Old Jun 5, 2011 | 04:08 PM
lukeytheduke
If u can run wasted spark on standard ecu then what are the benifits of spending all that cash on l8 p8?
Old Jun 5, 2011 | 04:11 PM
whizzisat114
L8 and p8 have the ability to run closed loop as standard
Old Jun 5, 2011 | 04:27 PM
lukeytheduke
Sorry mate but whats closed loop?
Old Jun 6, 2011 | 09:42 AM
lukeytheduke
upski!
Old Jun 6, 2011 | 10:05 AM
1374lee's Avatar
1374lee
Luke,closed loop is when the car will run at lambda 1 which is perfect fuelling at cruising speeds,air fuel ratio reading 14:7:1.It's standard on late sapps green stickered L8 and the escos p8 ecus,If you go onto motorsport developments website,take a look at the closed loop article that Stu has written,it will all be explained there for you.I hope this helps.
Thanks.Lee.
Old Jun 6, 2011 | 10:38 AM
lukeytheduke
do u know if motorsport dev prefer l8 or p8?
Old Jun 6, 2011 | 02:39 PM
1374lee's Avatar
1374lee
Luke they prefer L8 m8.
Thanks.Lee.
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
