EXHAUST WRAP!!!!!
EXHAUST WRAP!!!!!
alrite everyone
i want to wrap my turbo in it. it's a frst with a t3, so it's abit close to the rad
i need some help. can anyone tell me how much i will need for the job
cheeRS
cheeRS
DEMON THEIVES, BURTON POWER ETC SELL THE WRAP..
(sorry caps lock) its comes in 50Ft lengths IIRC.
i just one WHOLE roll just to do my manifold and turbo that was the 2" stuff.
Depends if your going to wrap just the turbo and the downipie or the turbo manifold and downpipe...as to how much you will need...
1 roll should do you for turbo and downpipe or turbo and mainifold but you will need more if you want to do the lot.
CheeRS
Phil
CheeRS
Phil
EXHAUST RAP
My exhaust is loud, my exhaust is bad
it's the best exhaust i've ever had ....
Fook mild steel & fook brass
it's stainless steel so kiss my ass..mofo!
Originally Posted by AJ
EXHAUST RAP
there are 2 different types thought aint there some to keep the heat out and some to keep the heat in. I ahve heard it can crack the manifold, anyone had problems using it????????. O and i take it its the wrap that keeps the heat in for the manifold. I was thinking of wrapping the charge carrier in the other stuff anyone done this??????????cheers
I was told it could crack the fanimold too.. but this was after i had spent about 4hrs removing wraping and re-fitting the turbo..
when i eventually too the wrap off (to repair turbo) the mainfold was fine.. and there was no damage/crack to it or even the exhaust housing on the turbo
Originally Posted by Twins
Had no trouble with mine cost about £90 to do though as i went down the down pipe
cheeRS for all the advice
Got all mine on ebay got one small lot for £15 which done manifold i then got 1 from america a huge roll off it well cheap as no one bid on it
