gearbox ib5 mtx????
I have a 1.4 cvh 1997 mk6 escort and release bearing has gone and will be changing but want to change gearbox as I feel like 1st and 2nd gears are really short I dont want extra speed as its only 1.4 just want longer 1st and 2nd
What box would be best one from a 1.6 xr2 or xr3 or from a dieasl
the xr2 and the xr3 mk4 wont fit the mk6 as they dont have 4 bolt holes on the front for the mount i have 1.8 desiel box out of a mk6 in mine and they are good boxes
New issue with gearbox/drive train I have had a very faint grinding metalic rubbing noise coming from passenger side front which I put down to speedo because it jumps about below 30 but today on way home from work its got a lot worse its only happens when jumping on gas quickly or coming of quickly if I pull of slowly I get no noise but if I try and pull of quick it grinds like a goodan.
Oh and the other thing should mention is that I think a mount has gone as engine jolts under harsh accelaration or deccelaration but cant really see a problem with gearbox mounts
Thamks for advice blunty07 have you got a 1.8 diesalbox on a 1.4 cvh how it pull????
chowfornow
14
05-01-2019 09:01 PM
cossirob
16-09-2015 07:39 PM
