Front hub removal, spindle carrier ball joint stuck
So the bearing on the front of my Escort (1997) needs replacing.
Got everything loose except the bottom ball joint that goes into the base of the hub. (From the spindle carrier I think it is called)
I was told that you simply get a great long pry bar and pry it down.
Well, I've bust a gut doing that. 3 hours later I'm just filthy and bleeding.
I pulled the hub off a little way with a puller to see if that would help, but there must be a knack I'm missing. Is there?
It can't be that difficult surely?
Thanks in advance, I've got a day off work tomorrow luckily, so I can start in daylight and sit down for some dinner now.
Tim
Tim
You have taken the pinch bolt out completely, right? Wont come out otherwise. I use a long extension bar, slide it down the back of the hub onto the bottom arm where the balljoint bolts are and give it a few whacks with a hammer, if it gets stuck, hit the balljoint back into the hub from underneath and try again. It comes out eventually, just a pig sometimes.
Cheers.
Yep bolt out and even got a pry bar in to open the gap.
Got the ball joint shaft out by about 10mm but 30mm still left to go.
Will try again tomorrow (or later this morning I mean)
Thanks
Thanks
if all that fails try a ball joint seperator fork
http://www.halfords.com/webapp/wcs/s...0151&langId=-1
hit a chisel into slot to open the hole up a little where the ball joint goes into. as u use the pry bay to lever the bottom arm down push the hub back toward the centre of the car. when u just pry it down the ball joint doesn't come down straight & will just stick
That is exactly what was happening. Got it out 10mm and the rest stuck.
I used a jack at an angle to push hub in as you say and it almost fell out.
Cheers for the help guys.
Safe driving
borboyous
22-08-2015 11:17 AM
Gadget
13-08-2015 08:19 PM
track.focus'd
12-08-2015 05:53 PM
