cossie gasket set... name that gasket game!
When the engine comes out next month i was going to just replace the gaskets and seals like for like but to give myself a head start can anyone name these gaskets from right to left in each picture (i havent pictured the really obveouss ones), if it helps theres a complete numbered set at the bottom
1 - camshaft bearing seals
2 - camshaft seals
3 - rocker cover half moon seals
4 - rocker cover gasket
5 - turbo oil return pip gasket
6 - rear of head water temp sensor (ecu) holder
7 - possibly rear main oil seal
11 - possibly rear main oil seal
12 - exhaust manifold gaskets
15 - head gasket
16 - inlet manilfold gasket
17 - plenum cover gasket
18 - throttle body to throttle elbow gasket
19 - bottom cover gasket
20 - aux cover seal/front main oil seal
21 - aux cover seal/front main oil seal
22 - watre pump gasket
23- thermostat gasket
24 - throttle elbow to inlet manifold gasket
25 - sump set
CheeRS
Steve
2 - camshaft seals
15 - head gasket
25 - sump set
CheeRS
Steve
Not sure from your thread if you already have these, but on the inlet side of things go COMETIC, they're re-useable, also for water pump, stat housing cometic again(re useable).
For the seals on cams, aux shaft, front crank use VITON, well worth the extra money, for this proper high temp industrial seal, the rear crank seal can also be got in VITON but seriously expensive this one, the std seals are ok here.
Can also get cometic r/c gasket, but check fit before using as often need just a tiny amount trimmed off the end tags where it sits under the half moon seals at the cam bearing retainers, you can also get a cometic one for the CTS housing.
these ones are all gen ford from matt lewis, i figured that if the original ford ones have held out for 100 thou miles then these will be fine for the next few years.
as you say though next time ill probably go cometic as the engine will probably be stripped and rebuilt more regularly when my workshop is built
im still stuck on 2nd pic number 1
and 3rd pic number 1 (like a double thickness cam seal)
and 3rd pic number 3 (the small metal washers x4)
Mc5506
05-10-2015 09:57 PM
