injector movement?
Old May 22, 2011 | 06:55 PM
fraser9764's Avatar
fraser9764
Default injector movement?
Just put my modified 4x4 (i think) fuel rail, with aeroquip fittings welded on, onto my new ST escort inlet with rochester 1000cc injectors and i get a fair bit of movement in and out of the rail/head, not enough to reveal the o ring either end but too enough to worry me slightly
ive read a thread from a while back with people saying this was a problem with some billet rails but this is all OE stuff apart from the injectors
also did the 2wd or 4x4 rails have injector clips? as the ST fuel rail i have taken off (i want to keep the aeroquip fittings) used proper clips to keep them secure.
Thanks.
Old May 22, 2011 | 06:56 PM
fraser9764's Avatar
fraser9764
you can just about see the rail here
Old May 22, 2011 | 07:06 PM
scoooby slayer's Avatar
scoooby slayer
i cant help with question but make 100% sure they cant leak fella, i narrowly avoided total meltdown 4 weeks ago due to leaking fuel on boost from a dodgy rail/injector set up !
Old May 22, 2011 | 07:10 PM
B13 JUS's Avatar
B13 JUS
have you fitted the clips?
Old May 22, 2011 | 07:11 PM
Paul_RS's Avatar
Paul_RS
All standard fit Cosworth fuel rails use the same clips, refit the ones from your ST rail onto the new one.
Old May 22, 2011 | 08:10 PM
All the std rails I've seen have clips, there is often the odd mm or two of movement, but so long as they are a snug-tight fit in the rail/inlet will be ok if only a few mm, they won't move in use, more movement than this and I'd be worried about wearing a flat on a seal.
Old May 22, 2011 | 08:13 PM
Mark Shead's Avatar
Mark Shead
There are no clips on the injectors.
Mark
Old May 22, 2011 | 08:32 PM
fraser9764's Avatar
fraser9764
The fuel rail on the old engine never had any clips fitted with the greens, i never tried fitting them last night as i presumed they were different and i had so much else to do, Will pop them on tomorrow
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
rsturbo27
Sep 5, 2015 05:08 PM
