transit diesel out of feul
08-05-2011, 04:30 PM
Anyone know how to start a 2001 transit diesel thats run out of fuel.Put a gallon in but still will not start.
08-05-2011, 04:32 PM
if you run out in a diesel dont you have to bleed to fuel line or something...
think i saw that on top gear once
08-05-2011, 04:34 PM
I think some are self priming
08-05-2011, 04:36 PM
08-05-2011, 04:42 PM
herbcosworth
crack nuts off on injectors and crank over till fuel comes out
08-05-2011, 04:51 PM
Quote:
Originally Posted by
herbcosworth
wont work, you will either have to tow start it and can take upto a mile or pull the fuel feed pipe off the fuel filter and and pull the fuel into to filter using a hand/electric primer.
08-05-2011, 05:05 PM
Sometimes there is a prime pump on top of the fuel filter.
With regards to bump starting, get it in 3rd and tow it from a standstill. The timing chain tensioner works on oil pressure and bump starting can cause the chain to jump due to lack of oil pressure.
Gavin.
08-05-2011, 05:10 PM
herbcosworth
08-05-2011, 05:17 PM
fill the fuel filter with diesel, crank it and spray easy start or brake cleaner into the inlet, not to much tho it mite knock a little.
08-05-2011, 05:21 PM
as said above ,you may take the fuel filter off and fiil it to the brim ,then prime and bleed
08-05-2011, 06:40 PM
fill the filter full of diesel and crack off the injectors nuts (19mm), crank it over until fuel comes out and no air.
dragging it up the road is an option but id use that as a last resort
TIP : never let modern diesels run out of fuel! lol
just keep cranking as the hand primer on the fuel filter is shocking good luck crank in bursts we had this at work and as per usual i had to help
08-05-2011, 06:50 PM
I'm sure it's something like 75 pumps on the filter pump!
08-05-2011, 06:53 PM
zetec turbo
bit of easy start will get it going mate i know the newer transits don't have hand primers
08-05-2011, 07:22 PM
there a COONT to do !!!
id fill the filter, squirt some easy or brake cleaner down the inlet, fire it up and hold the revs at a couple, repeat till right
08-05-2011, 07:29 PM
E36 cosworth
We had one at work that ran out of fuel. We had to fill 2 jerry cans of fuel to get it started as 1 was not enough and crack off the injectors.
08-05-2011, 09:04 PM
Sorted now, was low fuel but took filter off and found some crap in there cleaned it out bled it and it ran, so i've now filled up with diesel.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Neil Clark
21
01-10-2015 07:02 PM
fordfiestamk3
11-09-2015 12:52 PM
Bighandsuk
02-09-2015 05:23 PM
2000 ,
bleed ,
deisel ,
dielsel ,
diesel ,
ford ,
fuel ,
location ,
primer ,
ran ,
reg ,
run ,
tow ,
transit ,
work
