Gear Selection Issues - HELP!
Old May 4, 2011 | 06:08 PM
onslack's Avatar
onslack
Default Gear Selection Issues - HELP!
after a bottom end rebuild i now have gear selection issues when my engine is running, yet i can select a gear when the engine is off with the clutch down and start the car and it'll drive ok but selecting gears is very difficult( ive got a 2wd cossie by the way)
now the only things i have changed while the bottom end was rebuilt was the fly wheel( i went from a lightened 2wd fly wheel to a refaced 4wd fly wheel and a brand new thrust bearing from msd) new clutch was re padded and my pressure plate was reconditioned
ive booked it into a garage to have it looked at as i dont have the space to take the box off but i have been asked if there is there any difference between the 2wd and 4wd fly wheels?
Old May 5, 2011 | 01:41 PM
onslack's Avatar
onslack
anyone?
Old May 5, 2011 | 06:25 PM
scoooby slayer's Avatar
scoooby slayer
sounds like for some reason your clutch just isnt engaging far enough, my mate had this on his mki1 escort after clutch and flywheel customising and he ended up without enough travel to fully engage the clutch !
Old May 5, 2011 | 07:03 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
the clutch plate isent dragging is it as in not free to move on the input sharft and not moveing away from the flywheel when you press the clutch peddal? and the plate is deffo in the right way round is it (easy mistake to make!)
Old May 5, 2011 | 07:09 PM
The plate will only go one way round, due to hitting the flywheel centre if wrong way, was the plate a nice sliding fit on the splines of the box, I assume you checked first, if not it should have had some rubber grease applied here, as sometimes the plates jam to the input shaft splines and don't move away minutely from the flywheel, had the same when I got my cossie, took box off and applied rubber grease to cure perfectly.
Is your gearbox oil level correct, as in not super low, as this will make the box easier to spin, whereas the small drag caused by the oil stops it turning so freely and helps with this problem.
Old May 5, 2011 | 07:18 PM
ajamesc's Avatar
ajamesc
yep which would cause the clutch to be permanently engaged as the wrong side is butted up against the flywheel not saying it is just a thought
Old May 6, 2011 | 09:59 PM
boost mad's Avatar
boost mad
the splines wernt when it was put back together.
Old May 6, 2011 | 10:02 PM
ajamesc's Avatar
ajamesc
the splines wernt what?
Old May 6, 2011 | 10:12 PM
boost mad's Avatar
boost mad
my bad, not the easiest phone to type on when in the passenger seat of a old car
the splines wernt greased but the clutch was definatly the corrected orientation
Mark_
14
Jan 16, 2016 05:27 PM
The Youth.
Sep 30, 2015 09:59 PM
SMILER258
Sep 28, 2015 09:04 AM
