why vent a rocker cover?
why do people vent the rocker cover on a cossie, it seems a popular thing to do but are there actually any benefits in it?
i mean the pipe that goes from the back right corner to an oil catch tank
im sure Harvey/SCS said it wasnt necessary in a previous thread, and some people have had problems with them sucking the oil out of the head.
there shouldnt be any excess pressure up there anyway as the pressure is generated by piston blow-by.
my new engine will be breathing from both sides of the block and returning to sump, or catch tank, not decided just yet.
cossie fan (unluckerly)
if it was good enough for the rs500 touring cars its good enough for me lol plus cosworth must have thought it needed it or the hole wouldent be there but i see some dont
This seems to be the most confusing topic in the Cosworth world - i'm fitting my 5 port system up to the cam cover, inlet side, retrun exhaust side (not sump), 2x catch tank - some say it's wrong but it's been proven on +500bhp cars so it's good enough for me.
You will always get various opinions about this issue
But as said , if this way was good enough for the touring cars then its good enough for mine
The one at the back of the rocker cover actually vents the crank case not the head
... i could be wrong though, its just my understanding
thinking about it, i do agree with the above statement that the pressure would be caused by blowby gasses so on a fresh healthy engine it shouldnt be an issue,
think ill leave mine as it is since its getting a rebuild after classic ford this june
its there on all of them u just have to drill the blank out
As said there on all of them, if it's good enough for a RS500 race car!!, this bears little relationship to the road cars.
It doesn't matter how fresh newly built any engine is, they will ALL have blowby, even non turbo cars have blowby, that's how the oil gets contaminated!!
There will be pressure present in the r/c, as pressure will always seek the path of least resistance, the hole being a large drain hole return for the oil will have pressure, so this can be relieved by a breather, whether you need one depends on a lot of things, boost pressure being one, but even on a bog std cossie the breather system was marginal at best imo.
There are some theories that breathing from here would stop the oil flowing back, clearly this isn't and can't be the case, as the head would fill with oil starving the engine, and they don't.
I'm building my breather at the mo, from block both sides, r/c, and sump on off side, but instead of the useless tanks containing nothing but air, these will be filled with stainless wool, actually scrub buds so allowing air passage but not oil droplets.
Just my view.
Just my view.
I have my own theory on this,,,,,,,,take a plastic bottle(this is the space under the rocker cover).Fill it with water(the oil),turn it upside down,the water(oil) drains/glugs out of the lid.Now do the same again but make a hole in the top of the bottle(actually the bottom).This hole would represent a breather in the top of the head.Now see how quick the water(oil) drains out.
i thought most cars had this? not all going into a container though.
i was always told its a vac release for pressure that builds up in the rocker cover from the cams spinning.
even my fiesta has one i think, that filter just above my inlet mani above the fuel line is a vac release filter. it hisses when i turn the engine off for about 3 seconds.
i think all engines produce crank case compression and the breather systems help release this as it would start blowing gaskets
id of thought big psi car's would need to vent this pressure off also
i saw a thread before tab where you mentioned using wire wool / scrub buds, gonna copy that idea as it makes sense... otherwise the mixture of oil/air would just escape from the breather before being seperated
deathrider666
28-09-2015 06:12 PM
