drivetrain losses article interesting read
http://www.rri.se/function/functiond...pe=whitepapers
just download this white paper pdf, it wont let me link my downloaded file ?
And it also states how pointless the "coastdown" method some RR's use to guesstimate transmission losses.
Pointless because there is no load applied through any of the drivetrain.
yes as i said it is a proper interesting report on it. rototest dont do flywheel figures just hub. average loss in there tests of 9% hp 7% lbft are a much more realistic reduction imo
id guess that was to try and cover up the fact that cars made less than quoted power, was it about the xr4x4 ? im sure ive read they never made the quoted power.
Resident Wrestling Legend
it was an article about the dohc 4x4 sierra, i'll dig it out again if i can find it
there was another one where exciting figures were a bit dismal compared to today, i think it was the same car that was supposed to have a chassis that was only capable of handling 150 brake
PassionFords Creator
Anyone interested in such things may also be interested in an article I wrote some time ago about Dyno's.
Link here.
Link here.
something else i have read is that the losses are not linear. they get higher as speed increases upto a maximum of 17% but at slow speeds can be as low as 5%.
i see coastdown is utter bolloxs because of the simple fact that its being measured with no turning force applied to it.
Originally Posted by stu's article
CAN TRUE TRANSMISSION LOSS EVER BE MEASURED?
Yes, and it’s actually very easy. Whip the engine out and measure its power on an accurate engine dyno, install it back in the car and run it again on your chosen accurate chassis dyno. Use the power at the wheels figure only and subtract one from the other. Hey presto, pretty accurate transmission losses.
this seems to be the most comman system used
http://wzeu.search-results.com/r?t=p...dynocalc.shtml
my thoughts are probably yes it is accurate as working out peak power but over inflates the earlier curve of power figures.
07-10-2015 12:56 PM
