Ford TDDI or TDCI ??
Hi,
just looking at a few mondeos and some of the earlier Mk3's are listed as TDDI not TDCI.
I've seen TDDI Focus's (Foci ? LOL..) but never a Mk3 Mondeo...
What's the difference between the two, any advantages or dis-advantages of one over the other ?
Do the TDDI engines still have pump / injector issues and DMF problems on higher milages ?
cheers
Martyn
cheers
Martyn
TDDI are moon milers and are well known for 250-300k on the clock
They dont suffer injector issues etc
They are 115bhp iirc, 5 speed box, they do have dmf but never used to hear of failures untill the tdci came along with all its other issues on early models
my focus is a tddi and it drives like a new car for 11 years old and 104k on the clock, these are well known for 200k+ on them easily aswell
tddi with a remap and happy motoring for you
The TDCIs are not bad as long as you use decent quality fuel, ideally from a station that has had new or recent fuel tanks. I've seen a car last only 30k with injector problems caused by running on supermarket fuel.
You can get more power and efficiency out of the TDCI but you probably wouldn't notice the difference between the 2.
The TDDI can suffer injector issues but it's rare. Usual signs is loss of power and slightly uneven running with no fault codes in the ECU. Rare but it does happen.
We maintain a TDDI Transit which has recently clocked over 400k miles, still on the original pump/injectors. It's had a dual mass and a starter though.
sound good so far.
Are the TDDI any less refined than the TDCI generally? or once up to temp there's little or no difference..
nosier cold starting or anything like that ?
Ta
Ta
Final Q I promise..
I'm guessing the MPG on the TDCI is better, more modern engine and management etc but is there a huge difference of just a few MPG...
do you know what I could expect from the TDDI on a mixed cycle, urban and main roads..
My wifes car is only doing around 35 to the gallon so looking for a big improvement over that. I think I will still be better off even if Diesel is a few more pence per litre..
cheers all, appreciate it.
Spelling Club King!
The filter (if changed regularly) is very effective at stoping contaminants from the tank.
To the OP - If you're getting a cheaper, more leggy Mondeo I'd probably opt for the TDDI. It is more agricultural, not quite as frugal and not as quick - but if they do have pump/injector problems they cost less to put right - although you have got twice the number of pumps to worry about as they have a lift pump whereas the TDCIs don't.
As for MPG - it all depends on how you drive. But mixed urban I'd expect around 40mpg ish.
I also know cars that have had premature failures with 'posh fuel'. Most early fails of the injectors are due to badly designed pumps breaking up blocking the injectors, and nothing to do with the fuel.
You can get replacement high pressure pumps for around Ł500 now but the injectors are still about Ł150 each.
i unfortunately had the injectors go on my tddi when i had it at around 75k.
Not the cheapest thing to get fixed.
And yes, i had been running it on supermarket fuel!
I have a tdci now though and it feels far smoother and quieter to drive.
I'm going to buy today.i heave to choice from 2 1- is a 2,0 tddi 162000 miles on 2001 plate 5 speed and the second 1 is a 54 plate 2,0 tdci 112000 miles.please any idea wich one i beter.thanks
Her in doors had a TDDI focus until recently when she upgraded to a newer 1.6 TDCI mk2 and I have to say I miss it.
Not only does the TDCI not sound very nice (particularly when cold), but it doesn't tick over half as smoothly as the good ol TDDI did - that thing would start in -10 and not miss a single beat right from the off!
I understand the lift pumps get lazy in the TDDI's and eventually they won't start, but this isn't for many k miles...
Tom
Tom
I used to have the tddi Mondeo before the ST so can't compare them really tbh as one has far more power.
As said the tddi can go on forever, a taxi driver I know had one with 440k on it. Clutch was only thing changed a couple of times.
The earlier tdci engines esp the ST were more common to injector issues due to the mapping of them.
My tddi had near 170k on it when I sold it still driving fine, again as said the lift pumps on them fail around 120k but you can buy a genuine bosch pump for around Ł120 (same pump from ford is around Ł500 lol)
Personally I would never buy a TDCI engined ford again..
But there will be plenty of people on here who have had loads of them and never had any issues..
The common issues are well known and if you can get one cheap enough or the issues already sorted (with proper evidence, not just on the sellers word) then it's cheap motoring..
borboyous
22-08-2015 11:17 AM
