how do i turn down idle speed on cossie
as per title...
im idling at 1500 rpm, its a saph cosworth and id like to know if its possible to manually turn it down a little
is it something to do with the grub screw on the bottom of the icv?
Just make sure it's not the iscv making it idle too fast. Unplug the iscv when the engine is warm and see if the idle drops off. If it doesn't then it may just need some adjustment or you could have an air leak. If it drops down when you unplug the iscv then something is holding the valve open. Could be a faulty valve or maybe a tps fault
My mates just had to have his ISCV cleaned due to high idling; did the trick. Out of interest we tried one that i had lying around and it idled silly high, so will be getting that one cleaned as well
Cheers, Chris
Cheers, Chris
Thanks guys, must do mine
