wideband in tailpipe ?
if i fit a snug fit 6 " long exhaust pipe in my cars tailpipe, with wideband sensor in that clamped to exhaust, is it as accurate at wot for a/f readings compared to downpipe ?
well i just got in have made this up for tmrw, what ya think ?
its a msd lambda slug so should be sitting in the right position.
It wont work the pipe is to large and to short.
Drop it down to about 1.5inch and over 12 inchs long so it sits inside the box as it will pipe up air at high rpm.
Mark
As Mark - it's too large in diameter. I now know what you mean by snug fit - it shouldn't be like that, it needs to be much narrower. Much less likely to get contaminated with fresh air.
Rick
Rick
ah well if it goes lean then it could be fresh air lol
il try it in the morning if it fucks about i guess il have to start again.
thanks for letting me know peeps
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
If you're going to remake the pipe as per the above suggestions... I'd also recommend you put the sensor either upright or 90 degrees either side of.
Having the sensor at an angle lower than that can cause moisture to settle inside the sensor and as you can imagine, sensitive heated elements and moisture aren't a happy combo!
lol to put it in perspective mate the welder i used has 1mm wire on heavy argon. i weld up 1" plate normally, should of used my 185 amp but couldnt be arsed to change the gas over.
Yes I think from mem mine is 18inhcs, But also watch where it sits inside the box,
On a Escort cos place it on the right side of the pipe it can change reading as it sits at a angle to the baffle tube place it on the left and fixes it,
With a 2.5inch baffle tube on the same car you cant use the tail pipe ext as it sucks in in to the back box.
Mark
my silencer has 2 2" ports in the box as its 2 into 1 underneath car into a 5" backbox. i guess i could try and get through behind the back box into pipe again, but which pipe do i go in as it ts off into 2.
on the big pipe it was cruising at 14.7 stable then on part throttle as some boost came in got into 12s then 11.1 at wot but then showed going mega lean from 6k revs up, 17 afr lean which was no way accurate.
il put it this way when i removed the 1.5" pipe earlier it was pure black with soot from just a few pulls up the road lol its nice to be sure though thats its mega safe.
Mark
Mark
Your going to struggle a bit with that ridiculously large tailpipe mate. We have a slightly conical one for those so the inlet is larger than the outlet, helps a lot, but what helps most is having a sensor that actually shows when its got fresh air mixing in with the sample so you know to ignore it..
Weld a bung in the front this will be the best way.
Mark
downpipe is 5" too its mahoosive
the readings massively changed for the worse on the smaller pipe so pipe is causing issues for sure. what about if i had a pipe that was sealed inside the back box with a good 18" of pipe behind the probe ?
there is a lambda sensor in the downpipe already, on the ecu af feebback is switched off, so i guess in theory i could just remove that and put my lambda in there tmrw. even if closed loop was active its still errelevant to wot anyways so i guess i should just do that tmrw.
i tried turning af feedback on but lambda output still shows as 0 on display and fueling doesnt change at all on my sniffer so i guess the current lambda isnt actually connected to the ecu for some reason ?
so it shouldnt hurt anything then stu if i just remove the lambda and screw my wideband in there and run up the road.
