What turbo for my spec
Old 19-04-2011, 11:20 AM
NEIL A
NEIL A's Avatar
Default What turbo for my spec
Looking for some advice for the best turbo for upto 420 bhp giving the best responce with my spec.
I was planning on running a T34.55 to save the gearbox but I now have a straight cut box so can go a bit wilder on power.
Engine spec is
7.2:1 comp
ported head
mls gasket
long studded
BD14 inlet cam
55lb blacks
4wd inlet
Old 19-04-2011, 11:22 AM
NEIL A
NEIL A's Avatar
Should of said I want to stay internal gated and ideally keep the 4wd manifold.
Old 19-04-2011, 11:25 AM
R5FORD
R5FORD's Avatar
RB T38
Old 19-04-2011, 01:07 PM
Staffi
Staffi's Avatar
As Aaron says, or the 3071 will do the job...
T34.63 would be on it's knees at that power (if it'd make that is) but wouldn't be for long..
Old 19-04-2011, 01:31 PM
sierrafun
sierrafun's Avatar
good for 420+ 2871.. ball bearing always use for low lag .also 3071 ..also at t35 you can put morram shaft and go for 2.5 boost .cost is big..what ecu you have ?
Old 19-04-2011, 01:37 PM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Why do you want to keep the 4wd manifold?
Its far inferior for performance
Old 19-04-2011, 01:40 PM
Staffi
Staffi's Avatar
Chip, just a quickie and sorry to hi-jack your thread Neil..
What max -ISH power can be made by the 2wd Manifold??
Old 19-04-2011, 01:43 PM
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
For around the 400bhp mark i'd go GT2871R or for the 450bhp mark i'd go GTX3071R - that will give similar repsonse but have headroom in it later on to go for nearer 500bhp with an injector change.
Old 19-04-2011, 01:51 PM
fezzy240bhp
fezzy240bhp's Avatar
Wots wrong with a good old gt30
Old 19-04-2011, 03:07 PM
Chip
Chip's Avatar
Never personally tested it, but I know of a couple of cars that made it to around 600bhp on it.
Not sure I would want to go quite that far myself though.
Old 19-04-2011, 03:11 PM
sierrafun
sierrafun's Avatar
i know gt3582 for 600 in yb engine check this out internal as you wish 2 bar boost 420 + http://cgi.ebay.co.uk/Garrett-Turbo-...item1e5a54d10c
Old 19-04-2011, 03:27 PM
NEIL A
NEIL A's Avatar
Main reason chip is ease of fitment as far as heatshields and exhausts. Im not chasing power really and would be happy with 420 which shouldn't be at the limit of the 4wd manifold. The main reason I'm thinking of a new turbo is the car will need a remap when the cam gets changed so might aswell do all the changes at once.
Old 19-04-2011, 03:33 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
You would also benefit from bigger injectors, safety margin.
Steve
Old 19-04-2011, 03:36 PM
R5FORD
R5FORD's Avatar
why is the 4wd manifold not as good for performance? My engine runs it at 450hp
Old 19-04-2011, 03:40 PM
Staffi
Staffi's Avatar
Really Chip?? i always thought they were pretty dead after 400bhp...
Aaron, i think it is good for performance mate, as i've just said when quoting Chip, i always thought 400 ish was the limit of the 2wd one hence why i asked the question....
Old 19-04-2011, 03:42 PM
Chip
Chip's Avatar
It doesnt flow as well.
Old 19-04-2011, 03:44 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Are you talking about inlet or exhaust manifold postie ?, because Chip has answered for exhaust.
Steve
Chip
Chip's Avatar
God no mate, the rwd one is capable of pretty massive power really.
Porkie was on one at 600bhp for example.
Ade was just over that although had problems with the middle two cylinders caused by the lump on entry to the manifold we believe which hinders flow on those cylinders.
Old 19-04-2011, 03:45 PM
Chip
Chip's Avatar
Steve
Yes mate, I meant the exhaust, apologies if that wasnt what was being asked
Old 19-04-2011, 03:55 PM
Staffi
Staffi's Avatar
Steve
Arr, good spot Steve, wires crossed Chipa, yes i was referring to INLET fellas...
Old 19-04-2011, 04:04 PM
sierrafun
sierrafun's Avatar
in the 2 wd exaust manifold can you put external wastegate 46mm to go for 600 hp ?
Old 19-04-2011, 05:11 PM
Chip
Chip's Avatar
Yes you can, martin at reyland has done a few.
Chip
Chip's Avatar
Yeah 400ish seems to be about it.
Small turbo escos is the best of the bunch (barring the mega rare 500 ones)
Old 19-04-2011, 05:45 PM
scoooby slayer
scoooby slayer's Avatar
gt30 for me.
Old 19-04-2011, 08:36 PM
NEIL A
NEIL A's Avatar
With good mapping would a smaller GT30 be as responsive as a T34?
Old 19-04-2011, 08:37 PM
JamesH
JamesH's Avatar
GT30 all day!
Old 19-04-2011, 08:39 PM
JamesH
JamesH's Avatar
Yes it will match it upto 4000rpm and give you another 100hp above!!
Old 20-04-2011, 12:32 PM
NEIL A
NEIL A's Avatar
Well that gives me something to think about over the next few weeks, its just a shame there isnt many different spec cars up here in Scotland to get a run in before deciding. Will try and get a run in Kevs RBT38 car as that would be the easyest bolt on and go option.
Old 20-04-2011, 08:11 PM
KSA-Cossie
KSA-Cossie's Avatar
No sweat Neil,needs mapped first though.
Old 20-04-2011, 08:17 PM
NEIL A
NEIL A's Avatar
Well you have 3 weeks Kev chop chop
Old 20-04-2011, 08:21 PM
Kverna
Virgin-popper
Kverna's Avatar
Have you considered the EFR-series from B&W ?
EFR-7064 would be good on these power levels
http://www.full-race.com/articles/bo...fr-turbos.html
Old 20-04-2011, 08:36 PM
KSA-Cossie
KSA-Cossie's Avatar
Well the road tax in May is a start lol.
Old 22-04-2011, 12:51 PM
mark r
mark r's Avatar
think u should worring about your gearbox at 420 its gonna shit it self
Old 22-04-2011, 02:02 PM
scoooby slayer
for me it would be cossierich spec, i think thats his name with the gt30 on stock port head awesome road engine imo.
Old 22-04-2011, 02:24 PM
KSA-Cossie
KSA-Cossie's Avatar
Neil has a big tooth box mate.
Old 22-04-2011, 02:43 PM
JamesH
JamesH's Avatar
GT30 would kill a T38 with the right inlet and cam
Old 22-04-2011, 03:03 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Im happy with my spec , 480bhp and 485lb/ft @2.1bar
Steve
Old 22-04-2011, 03:07 PM
JamesH
JamesH's Avatar
Steve
Not saying you're not. But getting back to the original topic, if you had the chance to choose a turbo again, same prices etc etc - T38 or GT30 then?
Old 22-04-2011, 03:08 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Why change when my spec does the job ?
Steve
Old 22-04-2011, 03:18 PM
scoooby slayer
Steve
hows the t38 for surge ? can you run 2.1 bar straight up with no surgeing low down ?
my old t4 used to surge its tits off on standard port head with bd14s, had to be caped to this
Quick Reply: What turbo for my spec
