Using ABS ring for Stack speedo?
Old Apr 8, 2011 | 09:01 PM
Spiky's Avatar
Spiky
Default Using ABS ring for Stack speedo?
thinking of ideas to run the speed sensor on the 205,
i know i can use hub bolts, or a magnet on drive shaft
but how about utilising the abs ring on 205 hub which had ABS?
Old Apr 8, 2011 | 09:11 PM
left hooker's Avatar
left hooker
yeah if your any good with electrics theres trucks that do
Old Apr 8, 2011 | 09:13 PM
Spiky's Avatar
Spiky
why would i need to be good with electronics?
i have a stack speed sensor, just the case on making a bracket,
BUT using the ABS ring as a pickup
thats all i'm asking realling,
not using the ABS sensor as a speed sensor
Old Apr 8, 2011 | 09:15 PM
J1mbo's Avatar
J1mbo
B1mbo
In the stack kit there should be instructions on the minimum and maximum pick up points per revolution there should be, count how many teeth on the abs and see if it can be utilised
Old Apr 8, 2011 | 09:17 PM
Spiky's Avatar
Spiky
ok will do, cheers
left hooker
what does the stack sensor use to read rotaion ie magnets ?
Old Apr 8, 2011 | 09:19 PM
Spiky's Avatar
Spiky
i "think" the sensor it sensor it's self might be magnetic so just needs something to pass the end of it, like the rear of a wheel stud for example
Old Apr 8, 2011 | 09:21 PM
J1mbo's Avatar
J1mbo
B1mbo
As said just needs a magnetic metal item to pick up on, like a brake bell bolt
Old Apr 8, 2011 | 09:26 PM
left hooker
i know when the abs sensor is fitted and the wheels are spining (driving) they create a magnetic charge not sure that would mess with the stack sensor?
Old Apr 8, 2011 | 09:29 PM
J1mbo's Avatar
J1mbo
B1mbo
I don't think the abs is used? Its a track car so the sensor should be fine, need t make sure the tooth count is within the stacks range per rpm, I think it would be fine, as long as the the depth of the tooth is enough
Old Apr 8, 2011 | 09:33 PM
left hooker
the op said hes not using abs any more but the spinnig motion grenerates a magnetic field sort of
Old Apr 9, 2011 | 08:32 PM
It doesn't generate a magnetic field, it induces a square wave form using the abs ring, so long as it's within the range of "counts" per rotation of the wheel/(gearing) for the stack, it will be fine.
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Sep 29, 2015 09:06 AM
