2wd fuel pump problem
Old Feb 6, 2005 | 04:59 PM
Ratty's Avatar
Ratty
Default 2wd fuel pump problem
My fuel pump is not getting any power, the relay works, the wiring is fine as is the pump any idea's
Old Feb 6, 2005 | 05:11 PM
Alvyn's Avatar
Alvyn
have you check the switch in the boot is pushed down
Old Feb 6, 2005 | 05:12 PM
Ratty's Avatar
Ratty
Switch removed, so it aint that
Old Feb 6, 2005 | 05:37 PM
S2martin's Avatar
S2martin
Ex Full Price gold member
There is a fuse under the dash on the passenger side as i had mine go down and it turned out to be that
HTH
Martin
Old Feb 6, 2005 | 05:38 PM
Alvyn's Avatar
Alvyn
It must have a break in the wiring loom some where sounds like you'll have to trace it back until you find when the wire becomes live again! maybe
Old Feb 6, 2005 | 05:51 PM
ImaRacing 700's Avatar
ImaRacing 700
PLEASE PLEASE put the cut out switch back in...for your own life and others in the event of a crash.
Old Feb 6, 2005 | 06:01 PM
PMSL - you talk total shit....
Most infact 90% of crash's involve an engine stall.
PUMP thus turn off
Old Feb 6, 2005 | 06:05 PM
Ratty's Avatar
Ratty
All wiring is fine, the fuse is fine, pump is fine, cut off switch will be replaced once the damb things starts running, would it be a dead ecu?
Old Feb 6, 2005 | 06:07 PM
ImaRacing 700
PUMP thus turn off
Must tell car manufacturers that "the motorsport person" says dont put fuel cut outs in as he says fuck the 10% ...I think its you being fed too much bullshit thats made you say the things you do!
Old Feb 6, 2005 | 07:20 PM
Ratty's Avatar
Ratty
Any chance we could get back on topic please?
Old Feb 6, 2005 | 07:24 PM
bigal1978's Avatar
bigal1978
the fule pump live is at pin 28 on an l6 ecu
Old Feb 6, 2005 | 07:25 PM
bigal1978's Avatar
bigal1978
do u have a live at the relay ?
also a freinds ecu was shaged had a good spark ect pump would not work no power from the ecu
Old Feb 6, 2005 | 07:41 PM
Ratty's Avatar
Ratty
The relay has live on the large red wire, cant remember if it had an output on either of the other 2 small wires and obviously it had nothing on the black and red, I'll check pin 28 for an output tomorrow, I'm beginning to suspect the ecu
Old Feb 6, 2005 | 07:44 PM
bigal1978's Avatar
bigal1978
i belive the big red wire cums from the other main yellow realy next to it i cant remeber the coulor of the ecu to relay wire but i do no its pin 28 if in doubt send it to pj motorsport or like wise thay can test it if i wernt so far away i would lend u mine
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
