help needed: setting solid tappets on a cvh
Old Mar 30, 2011 | 06:06 PM
luke89's Avatar
luke89
Team HOTHOT!
Default help needed: setting solid tappets on a cvh
hey people just after a bit of help, iv almost complited building a cvh for a mate but just stuck on the tappets , what order should i do them in ? eg number one is tdc then i should do ... number? and also what should the clearance be? its a kent fast road cam cant remeber the number .
thanks in advance
luke89
Old Mar 30, 2011 | 06:40 PM
Icurus's Avatar
Icurus
Rule of 9, when say 8 is at full lift, check number 1, iirc
No idea on what clearance you'll need though, have you checked the Kent website?
The cam should have an id mark on it somewhere, either at one end or around the middle?
Did your mate not know what cam he had, did you not check before the build? how do you know it will not foul the pistons etc etc
Old Mar 30, 2011 | 07:31 PM
JonathanJ's Avatar
JonathanJ
You can also do them "on the rock" when no 1 is at tdc with inlet valve just opening and the exhaust jut closing on the overlap then adjust no 4 , and visa versa , and when no 2 on the rock do no 3 and visa versa .
If you go here
http://www.kentcams.com/info/catalogue_lowRes.pdf
then you will see on the cvh cams there is slightly different clearances required 0.15/0.20 mm for CVH26 and 0.56/0.61 for CVH27/28
Hope that does not cause to many problems .
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
gcfcos
88
Sep 15, 2015 03:48 PM
RSmark84
Sep 13, 2015 01:29 PM
3doorcozmess
Sep 7, 2015 01:32 PM
