cvh 35 kent
cvh 35 kent
hi guys
i have a cvh 35 in my stage 4 head for my 2.1 zetec turbo, does any1 know the timing settings for the verneer pully wheel, its already set at 11 dgrees retard;
cheers kev
cheers kev
Hi Bud,
Where did you get that reading (11deg retard) ?? (The numbers on the vernier pully mean bugger all at this point)
You need to get a timing disc on the bottom pulley, Set this up to tdc and then get a DTI gauge set onto number 1 inlet valve. Take your readings from there.
The lift at TDC for the CVH35 is 0.73mm as I had the same cam in my old ZVH.
Hi Bud,
cheers kev...., just read tht again bud av got you
Bodybuilding
Location: Cannot be identified by the information given.
that is too much retard for the cam, set it to -5 retard untill you get it setup
You will need a timing disc and at least 1 DTI gauge to be able to set the cam up to the correct timing , have a look on you tube if you want to learn a bit more
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
