Throttle position sensor failure??
Old Mar 30, 2011 | 04:42 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Throttle position sensor failure??
If you have 5 minutes and dont know the aggro i have had could u please take 2 minutes to read this..
https://passionford.com/forum/genera...ease-help.html
Anyways today i swapped coilpacks with a mate, and it was no better (still cutting out wouldnt run)
then we took the Throttle position sensor of and she ran!
has anyone heard of a throttle position sensor causing aggro like this before? hope ive found the problem, will have to get one ordered!
Old Mar 30, 2011 | 06:34 PM
cabriolet's Avatar
cabriolet
audi vw do this when throttle body dirty erratic idle flatspot crap fuel consumption tps is on the side of it
Old Mar 30, 2011 | 06:38 PM
dave cummings's Avatar
dave cummings
Im suffering something simalar
https://passionford.com/forum/genera...-04-1-6-a.html
Old Mar 30, 2011 | 06:50 PM
Adam.'s Avatar
Adam.
well im assuming mine is the TPS as when i plug it back in, the engine stalls, when i unplug it it runs, and if i have the engine running with the plug out then go to plug it back in, the engine starts to stall, if i remove it the stalling stops and she runs ok again......can anyone tell me if they have had simular syptoms with the tps?
Old Mar 30, 2011 | 07:01 PM
Adam.'s Avatar
Adam.
you mean they disconect it when they have those problems?
Old Mar 30, 2011 | 07:52 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
have you even changed the map sensor!? you may be totally off with the TPS that will just allow it to rev. mine had a std 2bar on and it was faulty and had the same issue, swapped it for a new one and ran PERFECT.
Old Mar 30, 2011 | 07:55 PM
jayRS's Avatar
jayRS
the TPS does wear and will cause problems, im PM'ing to on FT mate
Old Mar 30, 2011 | 08:39 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
change it and your all good to go chap
Old Mar 30, 2011 | 08:44 PM
JonathanJ's Avatar
JonathanJ
posted on other thread , sounds as if it could well be the tps , but have a read
Old Mar 30, 2011 | 08:51 PM
vaughant's Avatar
vaughant
Deffo tps,had it on my xr2i years ago,took it too ford who did just that,disconnected it,then put a new one on,ran perfect afterwardsI tried all the usual,crank sensor etc and it was that,I think it went closed circuit,therefore telling the engine that it was at full throttle and the ecu wouldn`t allow it to start or vice versa.
Old Mar 30, 2011 | 09:03 PM
Adam.'s Avatar
Adam.
will buy both the tps and map sensor to be sure
Old Mar 30, 2011 | 09:05 PM
vaughant's Avatar
vaughant
map went on my mates escos before and wouldnt start so worth doing both!!!!
Old Mar 30, 2011 | 09:09 PM
Adam.'s Avatar
Adam.
Are they both still available to buy from motor factors?
Old Mar 31, 2011 | 07:50 AM
JonathanJ's Avatar
JonathanJ
Map is available as it is the ofab type and these were used on many cars , the tps is a different story , have been looking myself but with little joy , hence the reason I have gone and bought a full xr2i engine complete with all the sensors and bits to make sure I have a spare
Old Mar 31, 2011 | 07:57 AM
JonathanJ's Avatar
JonathanJ
check here https://passionford.com/forum/ford-s...ps-please.html
check your part no
Old Mar 31, 2011 | 08:04 AM
jayRS's Avatar
jayRS
ford do or did still have some a while back but they are not cheap by any means.
due to the expense, and the fact of how hard it can be to get one, i always keep a full stock of all sensors, last count i think i have about 12 TPS and i keep finding them lol
anyway, i was told many years ago, but never followed it up, that maplins sell a variable resistor that will replace the TPS, at the end of the day the TPS is only a variable resistor with a moulded case round it, so if you can match the values for a ford TPS to one maplins sell you should be sorted.
as i said i never followed this up by buying one and testing it, but i was given a link at the time to the resistor and i was going to get one to try, but it was so long ago now i couldnt say which it was
Old Mar 31, 2011 | 12:53 PM
adamski frst
local motor factors will have a MAP Ł60, TPS just get a s/h one, very rare a tps would cause a issue tho TBH
Old Mar 31, 2011 | 02:09 PM
Andie's Avatar
Andie
I would also check there are no wire brakes near the end of the TPS plug. My 2i had an on off judder and replaced plugs, leads, coil pack and TPS and it was the wire. They did take the replacement parts back off!
Old Mar 31, 2011 | 03:23 PM
adamski frst
as above yes that was going to be another thing i had 1 time, a break in a wire going to the coil pack and made the car run like shit and took ages to find as the plastic made the wire look comlete but there was a break...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
