engine problems
Old Mar 30, 2011 | 06:52 AM
savo's Avatar
savo
Talking engine problems
i need help to know how to test an ecu on a ford fiesta 2008 1.6dci plz.
as the car does not turn over off the key,and the radiator fan stays on and it keeps drainin the battery.thanks
Old Mar 30, 2011 | 07:04 AM
B19 JUB's Avatar
B19 JUB
cooling fan relay problem mate.its in the square junction box behind trhe battery.quite common on the 1600 tbh
Old Mar 30, 2011 | 07:15 AM
martysmartie's Avatar
martysmartie
If it's not turning over then it's more likely to be an immobiliser issue or an electrical problem, the fans are controlled by the ECU but not sure if they would run when the engine is switched off? As said make sure you don't have a "sticky" relay.
Martin
Old Mar 30, 2011 | 09:34 AM
B19 JUB's Avatar
B19 JUB
if u have another key try that also
Old Feb 14, 2012 | 12:42 PM
fiestatdci's Avatar
fiestatdci
hi im pretty new on here, ive recently had the same problem wiv my mk 6 fiesta tdci, i fiddled with the brown relay in the black box next to the batterery and the problem went away but i have bort a new relay is it wise to put the new relay in now or would adjusting the old relay cease the problem permanently
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
