putting resistors on seat belt tensioners and airbags etc
i have a numpty mate of mine with a 307 put racing seats in so no tensioners etc, now i know you can fool the airbag etc into thinking they are fine with 3 ohm resisor etc the same with wheel airbags etc
my question is are all makes diff resistance or will 3ohm fit all?
becuase then he would have to have them floating around under the seats, think he wants to change the steering wheel too so that one will have to be done or the light will be flashing on
no cause the computer in middle has a spaz attack flashing airbag fault lol
god knows why on a 307 but you know what these nippers are like
hmmn might be 3.3k ohm???
Lee you will get away using a 2.5 ohm resistor in each line that you are disabling and depending on what year the 307 is it will either have the pretentioner in the seat belt stork or seat belt reel also check if it has side airags uilt into the seats hope that helps ?.
Regards Doug.
Regards Doug.
borboyous
22-08-2015 11:17 AM
