gt30 on std engine
Old Mar 21, 2011 | 12:33 PM
xr4x4rs's Avatar
xr4x4rs
Default gt30 on std engine
how would a std engine get on with a gt30 on it, running a std head bolts and a grp a head gasket?
injectors would be 83lbs, plus usual stuff like cooler, breather etc
as im looking for a turbo as i only want stage 3, but carnt find a t34 unless i get new and for a bit extra i could go gt30
Old Mar 21, 2011 | 01:14 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
See my project thread. Clicky in my siggy.
Old Mar 21, 2011 | 02:08 PM
xr4x4rs's Avatar
xr4x4rs
thats cool and a nice spec, but i hae a completely std engine, where yours has a bd14 so must have pocketed pistons?
Old Mar 21, 2011 | 02:12 PM
CossieRich's Avatar
CossieRich
Yes but you can get away with non-pockted pistons and a BD14. Depends on how much skimming your head has had.
But in terms of a GT30 on an engine still using standard head bolts then yes it can be done. I would change the h/g for a metal one though, providing both head and block surfaces are completely flat.
Old Mar 21, 2011 | 02:13 PM
Staffi's Avatar
Staffi
Rich,
You know thought of the T38 like Cossie4i has on his??
Old Mar 21, 2011 | 02:42 PM
xr4x4rs's Avatar
xr4x4rs
hate t38s mate, too laggy from what ive read, id either go back to a t34.63 housing or go gt30
i wanta go gt30 but then the car is going to be my everyday car until i decide to sell it, so dont want to keep blowing head gaskets lol
the head has just had its first skim aswell, problem is i carnt have the block decked unless i remove everything then id want to rebuild it and tbh i dont want to i just want get the thing in and use the car before i serious lose interest
Old Mar 21, 2011 | 03:21 PM
Mike Kerbey's Avatar
Mike Kerbey
Im sure you would lose all your interest if you put a gt30 on it and blow the head gasket. Do it properly the first time round and not the second or third time. Highly recommend getting your block decked, don't just put a fancy head gasket on and expect it to last.
Old Mar 21, 2011 | 04:18 PM
xr4x4rs's Avatar
xr4x4rs
i wouldnt, id rather stick with a t34 and a grp a head gasket, there is no way im stripping the bottom end lol
hence asking the question about std bolts and grp a gasket, obviously if the engine lets go on the y34 i may rebuildit or breakit, im only going to use the car for a couple of months anyhow i think, but that may change when i actually finish it and get driving it
Old Mar 21, 2011 | 05:54 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im using standard head bolts, Wire ringed block with a GrpA H/G with my TT T38, hits a good 2.2bar and i don't find it laggy at all.
Steve
Old Mar 21, 2011 | 08:01 PM
v man's Avatar
v man
Zee Germans are coming
i use a tt t38 and its not laggy one bit ???
if a engine is built and speced properly and not a bolt this on and use that then it will all work together as it should
i hit 2bar at 3.5k
engine revs like a motor bike
and im using an area 6 full on zetec turbo not yb
Old Mar 21, 2011 | 08:05 PM
xr4x4rs's Avatar
xr4x4rs
yeah but im not rebuilding the engine lol
if i was to rebuild the engine id spec it for a gt30
but by the looks of things, im gona have to stick with a t34, as i carnt have the block decked
Old Mar 21, 2011 | 08:13 PM
v man's Avatar
v man
t34 on a 48 or 55
i think the 68 takes the lower down punch away
Old Mar 21, 2011 | 08:20 PM
COCHYN's Avatar
COCHYN
You take short cuts with a YB, you'll pay the price. GT30 on a stock engine is just silly IMO, don't do it!
Old Mar 21, 2011 | 08:21 PM
xr4x4rs's Avatar
xr4x4rs
ill just stick with t34 and 63 housing like ive always ran, but instead of going 55lbs injectors ill go 83lbs
Old Mar 21, 2011 | 08:23 PM
COCHYN's Avatar
COCHYN
Mine will be running on a T34.63, 200 block, Mahle SCS spec pocketed 7:6:1 pistons, Light Blues. Should be mental enough
Old Mar 21, 2011 | 08:25 PM
dave cos4x4's Avatar
dave cos4x4
You will be surprised what a standard engine can produce.
Old Mar 21, 2011 | 08:29 PM
little bram's Avatar
little bram
Why do you need to get the block decked? gt30 should work fine on a standard yb with grpA bolts and gaskit mate as long as it set up for it with the right injectors.
my brother was running a standard yb with grpA gaskits and had a t4 and light blues at 2 bar boost. he used it every day and i didnt think it was laggy. was a nice car to drive
just put one on and try it
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
Dicko&Vacant
Aug 23, 2015 03:11 PM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
