Sponsored by:
Sponsored by:
Escort cosworth cylinder head bolt torques and order?
Old 05-02-2005, 05:38 PM
DaveEscos
DaveEscos's Avatar
Default Escort cosworth cylinder head bolt torques and order?
can anyone please list the torques and the order in tightening please
i want to check them, is this advisable? i mean should i go around and check them, tighten them if needed?
cheers
Old 05-02-2005, 05:56 PM
Turbo lag
Turbo lag's Avatar
up because I want to no as well
Old 05-02-2005, 06:08 PM
Eagle
Super Moderator
Eagle's Avatar
i would say not to touch em mate.... as they are tourqed to a set spec then tightened a bit more normally 90 degrees .. so you would actually be overtightening em .. and they could snap
Old 05-02-2005, 06:10 PM
DaveEscos
DaveEscos's Avatar
ok mate, thought they had a final torque setting
cheers
Old 05-02-2005, 06:39 PM
Eagle
Super Moderator
Eagle's Avatar
found the information you require
Lubricate head bolts at threads and under bolt head and install bolts together with washers.
Tighten cylinder head bolts as follows:
Stage 1 requires to tighten all bolts 30-35 Nm.
Stage 2 requires to tighten all bolts to 67 -70 Nm following the sequence.
Stage 3 requires the bolts to be tighten in degrees of rotating using a special gauge tool.
Following the sequence, each bolt is turned 80° - 90° of rotation
https://passionford.com/forum/viewtopic.php?t=63061
Old 05-02-2005, 06:44 PM
DaveEscos
DaveEscos's Avatar
Old 05-02-2005, 07:22 PM
Paul Eggleton
Paul Eggleton's Avatar
Dave, when I did my RST, Karl also said if you're putting a head back on, then leave it 20mins between stages.
I didn't use a special angle wrench, just a blob of tipex on the top of the bolt so I could see 90degrees..
Old 05-02-2005, 07:30 PM
Ginge !
just finding my feet
Ginge !'s Avatar
techy stuff there , but thats how mine where done after i got it back from paul hills , as he dont the standard ford settings, so i have 3 days between the first stage
Old 05-02-2005, 07:58 PM
Turbo lag
Turbo lag's Avatar
? explain
Vincereese
01-06-2023 09:14 AM
James Porter
26-08-2015 10:51 PM
Vincereese
16-08-2015 06:38 PM
Bobby9779
11-08-2015 06:47 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Escort cosworth cylinder head bolt torques and order?
