Saph window switch blubs
Old Mar 13, 2011 | 06:17 PM
fraser9764's Avatar
fraser9764
Default Saph window switch blubs
the illumination behind the switches doesnt work, i had a quick look today and im guessing you have to take the actual switch unit apart? Does anyone know what bulbs i need? Also the fog light and heated window icon illumination.
Old Mar 13, 2011 | 06:21 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
sapphs dont have illuminated window switches but i did add some leds to the in side of my ols one so the gap lit up around them
Old Mar 13, 2011 | 07:38 PM
As above don't have them, I've often thought of adding some soft amber leds to them, can be just wired on permanently, won't kill the battery as very low drain from led's.
Old Mar 13, 2011 | 08:07 PM
fraser9764's Avatar
fraser9764
that explains why they dont work then!
any thoughts on the fogs and heated window icon bulbs? they must have them as one of the 4 works.
Old Mar 13, 2011 | 08:26 PM
martysmartie's Avatar
martysmartie
First off do the actual outputs work, if not then there is a good chance there no power to start with, they should illuminate amber when on and I should think you would have to dismantle the switch to replace the bulb/LED.
Martin
Old Mar 13, 2011 | 08:35 PM
fraser9764's Avatar
fraser9764
yep the switches work perfectly, as do the lights in the middle of the button.
its just the backlight behind the icon which shows which switch is which that doesnt work.
Old Mar 14, 2011 | 01:23 PM
martysmartie
Oh that one, I should think the same applies, you would have to remove the switch, but don't think it's replaceable and if it was they are going to be very small bulbs if not LEDS.
Martin
Old Mar 14, 2011 | 01:34 PM
jon@work's Avatar
jon@work
they are LEDs soldered into place, but you can replace them
Old Mar 15, 2011 | 12:11 PM
As jon says led's, can replace with a colour of your choice, about 10 pence each!!
Get 12v versions, as space can be limited for adding a resistor.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
