should my rs turbo cut out when the oil cap is removed??
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
If you have Mfi with aftermarket oil seperator which vents to atmosphere it won't make a difference when you remove cap as feed to metering unit willbe blocked.
If you run standard breather set up to metering unit then it should cut or dip down when you remove cap as it creates a leak.
