Rollcage tubing spec.
Wye Valley Hardcore
I need to extent the front hoops to sit behind the dash on my rollcage and at the same time might as well order enough to do a rear turret strut brace, fixed door bars, harness bars and link the B pillar posts at the floor.
I know FIA/MSA spec needs it to be CDS steel but can you use regular seamed tube? Or will it shit itself in the event of an accident?
They will all be straight sections, so no risk of splitting when they are bent.
Wye Valley Hardcore
Yeah I'd want to keep it all the same Diameter which on the Saftey Devices 6 point is 2" IIRC? Do it properly with CDS I think then. £££
Acctualy scratch that i frogot your going to weld it in ....... could you maybe cut your dash down so it was removable ....
Wye Valley Hardcore
Yeah I was just refering to good practice as I won't be competing in anything that needs regs. No point having a cage which looks great then you crash the car and it turns into a 'punji pit' when the tubes split ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
I just want to add a few bits to beef it up as it's only a 6 point, but taking some measurements and looking at the angle of the 'A' pillar bar, it would only need a straight extention then reuse the existing bend and to the floor bar behind the dash.
Beef it up with the blue sections, extend with the green section.
![](http://img.photobucket.com/albums/v283/murray_eversham/caGE-1.jpg)
Wye Valley Hardcore
Adding those blue lines in blue could only make it stronger IMHO, though consideration should be given when welding not to overheat the nodes - but thats about it.
However, CDS isn't really that much, and it is far stronger...
Tom
Tom
Wye Valley Hardcore
Wye Valley Hardcore
Notchings not a problem.
nico12
31-12-2015 04:42 PM
