turning down brake discs ??
Monte 087
You could put them out of balance if you skim the OD of a disc mate, I know it is only 5mm a side but if you look at a brake disc they are machined to balance them and you might take this away if you skim them down.
Machining that much off the od should be ok,it's when you try to narrow them the problems occur,I helped produce millions of discs in ford!
I helped make a lot of scrap as well!!!
..BS Motorsport..
These the phateon discs beefy? Im seriously considering a set before someone realises the tuning world are buying them up and the prices start to rocket!!
kinda mate
the fronts aint a prob , as 18s will take em ,
but there rears are 310 mm , was hoping to get them down to 300 ,
but in reality the 310s wouldnt cause an issue ,
plus with me going granny 5 stud hubs there a bolt on item![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
just need calipers and bracketry making ,
..BS Motorsport..
Just checked the pcds myself, granny or galaxy hubs seem to be the same. Ive got some big calipers so Im thinking new hubs and brackets and game on. Im a 17" wheel though so it maybe a case of turning them down til they fit.
