Ryan loom info needed
Hi,
Just to try and save myself some time tomorrow need to know the wire connection as its from a 4x4 saph but going into an escos so need to know what the wires are in the block connector...
so starting at one end the colours are
Black
RED large
RED large
red small
white
white
any info would be helpful otherwise will cost me time tomorrow and i aint got much of it at the min.....
Black
RED large
RED large
red small
white
white
this is is the p8 pinout
you might need to pin it out to find where they go
Pin 1 - Earth (brown)
Pin 19 - Earth (brown)
Pin 2 - Lambda sensor (brown/white)
Pin 20 - Power (red)
Pin 3 - Crank position sensor (brown/yellow)
Pin 21 - Not used
Pin 4 - Crank position sensor (green/red)
Pin 22 - Knock sensor (blue/yellow in shielded cable)
Pin 5 - Distributor phase sensor (green/yellow)
Pin 23 - Distributor phase sensor (black/red)
Pin 6 - Knock sensor (black/yellow with brown earth from shield)
Pin 24 - Pin 3 Ignition module (Black)
Pin 7 - Canister purge valve (brown/white)
Pin 25 - Pin 6 Ignition module (black)
Pin 8 - Electronic control loom (blue/white)
Pin 26 - Not used
Pin 9 - Connected throttle pot wire (Pin 30 red) (white)
Pin 27 - Electronic control loom (blue/yellow)
Pin 10 - EFI power relay pin 85 (relay 8) in fuse box (plug M3BB at fuse box) (blue/yellow)
Pin 28 - Fuel pump relay pin 85 (relay 9) in fuse box (plug M5B at fuse box) (blue/gree)
Pin 11 - Map sensor (shielded) and link to common connection* (brown/green)
Pin 29 - Coolant temp sensor (black/green)
Pin 12 - Not used
Pin 30 - MAP sensor and throttle pot sensor (red)
Pin 13 - Octane adjust (black)
Pin 31 - Air charge temp sensor (red/green)
Pin 14 - Octane adjust (black)
Pin 32 - Injector 2 (brown/black)
Pin 15 - MAP sensor (black/red)
Pin 33 - Injector 3 (brown/black)
Pin 16 - Boost valve (brown/yellow)
Pin 34 - Idle speed control valve (brown/yellow)
Pin 17 - Throttle pot sensor (black/red)
Pin 35 - Injector 1 (brown/black)
Pin 18 -Injector 4 (brown/black)
*Pin 11 (brown/green) connects to the following....
Coolant temp sensor
Throttle pot sensor
Aircharge temp sensor
Pin 21 - Not used
Pin 26 - Not used
Pin 12 - Not used
Coolant temp sensor
Throttle pot sensor
muz
16-08-2015 12:57 PM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
