car does not switch off
Old Feb 20, 2011 | 02:13 PM
ford addict's Avatar
ford addict
Default car does not switch off
hi all a friend of mine has got an escort mk4 with an 1100cc engine.the problem is that when he turns the ignition off it keeps on running for a few seconds.any ideas of the fault.
thanks to all
Old Feb 20, 2011 | 02:22 PM
Tank Mike's Avatar
Tank Mike
Timing, or carbon build up on the exhasut valves.
Old Feb 20, 2011 | 02:25 PM
ford addict
we checked the timing already mate so its got to be carbon.thanks
Old Feb 20, 2011 | 02:48 PM
S1's Avatar
S1
Back when I was playing around with Mini's, we used to add an anti-dieseling solenoid from an A-series Metro, it's just a valve that when the ignition is switched off opens to atmosphere and prevents it from running on.
Old Feb 20, 2011 | 03:14 PM
chris m1's Avatar
chris m1
anti run on valve is stuck ot fubard
Old Feb 20, 2011 | 06:58 PM
Running on or "dieseling" is indeed normally caused by the timing, but also can be by carbon build up in the cylinder creating a hot carbon spot that ignites the fuel.
As said anti dieseling valves were fitted that simply opened to atmosphere making the mixture so weak it wouldn't ignite, pretty sure the 1100's had these as standard though.
Shows & Track Days
Aug 26, 2015 05:11 AM
Perfmr2
Aug 6, 2015 07:30 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
