headlamps
I own a st170 mk2
have a problem with my headlights lenses when you look @ them they look yellow can anybody give me a clue how to remove the yellow tinge
cheers![Wall](https://passionford.com/forum/images/smilies/wall.gif)
cheers
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
You can do this perfectly, if you take your time with maguiars plastic polish no10 and plastic cleaner no17, micro cloth and foam pad.
It is also possible top get a AS NEW result using wet and dry, basically exposing a new layer of plastic, then polishing.
Just do a search on the net there are various methods, but using abrasive paper works best, just takes a while, about 1 hour to 1 1/2 hour each light.
The toothpaste certainly seems worth a go, might depend on how bad it is ?, but certainly worth a go to start with, good find that was.
Toothpaste is also useful for putting up pictures from newspapers(sun page 3) on prison cell walls as well, as not allowed glue!!
GUZZLER
39
07-03-2006 03:05 PM
GUZZLER
07-11-2005 05:14 PM
