any vauxhall techs know what this could mean
Passionford Addict
as above peeps
the wifes 2003 1.6 astra club has started playing silly buggers. she came out the shop after 5 mins tonight and the car was running fine before hand and now this light was on and its went into 'limp' mode.
She came home and i went straight out and started it and all was fine.
left it for 10 mins or so and popped out in it myself.went about a mile,turned it off for a couple of minutes and back on again and all was well. Dropped off something to a mate and chatted to him for 10 mins or so then left and its at it again and now its staying on.
1910c9cb.jpg?t=1297371753
any ideas folks,all suggestions appreciated
Get in car and depress both the brake and the throttle and turn ignition lights on. The amber car with a spanner on should go out and a sequence of flashes will start. Each code is 4 digits long so for a code of 1481 you will get 1 quick flash, pause,4 quick flashes, pause, 8 quick flashes, pause, 1 quick flash. if there is more than one code you will have a pauise again and another sequence of flashes. a flash of 10 denotes 0.
These are the codes I have been supplied with.
0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) C-29
0036 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2) C-31
0100 Mass or volume air flow circuit high input C-10
0100 Mass or volume air flow circuit low input C-10
0110 Intake Air Temperature Circuit High Input C-12
0110 Intake Air Temperature Circuit Low Input C-12
0115 Engine Coolant Temperature Circuit High Input C-11
0115 Engine Coolant Temperature Circuit Low Input C-11
0115 Engine coolant temperature circuit malfunction C-11
0120 Throttle Position Sensor (TPS) Circuit 1 Voltage High C-09
0120 Throttle Position Sensor (TPS) Circuit 1 Voltage Low C-09
0120 Throttle Position Sensor 1-2 Correlation C-09
0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-30
0130 O2 Sensor 1 Circuit Voltage Low C-30
0130 O2 Sensor 1 Open Circuit C-30
0130 O2 Sensor 1 Incorrect Signal C-30
0134 O2 Sensor Circuit Open (Bank 1 Sensor 1) C-30
0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-29
0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) C-29
0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) C-29
0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-32
0136 O2 Sensor 2 Circuit Voltage Low C-32
0136 O2 Sensor 2 Open Circuit C-32
0139 O2 Sensor 1 Incorrect Signal C-30
0140 O2 Sensor 2 Incorrect Signal C-32
0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) C-31
0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) C-31
0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) C-31
0170 Rich Exhaust C-30
0170 Lean Exhaust C-30
0201 Cylinder 1 injector circuit high C-23
0201 Cylinder 1 injector circuit low C-23
0201 Cylinder 1 Injector Circuit Open C-23
0202 Cylinder 2 injector circuit high C-24
0202 Cylinder 2 injector circuit low C-24
0202 Cylinder 2 Injector Circuit Open C-24
0203 Cylinder 3 injector circuit high C-25
0203 Cylinder 3 injector circuit low C-25
0203 Cylinder 3 Injector Circuit Open C-25
0204 Cylinder 4 injector circuit high C-26
0204 Cylinder 4 injector circuit low C-26
0204 Cylinder 4 Injector Circuit Open C-26
0219 Engine overspeed condition C-43
0220 Throttle Position Sensor (TPS) Circuit 2 Voltage High C-09
0220 Throttle Position Sensor (TPS) Circuit 2 Voltage Low C-09
0220 Throttle Position Sensor 1-2 Correlation C-09
0230 Fuel pump secondary circuit high C-07
0230 Fuel Pump Relay Open Circuit C-07
0300 Misfire Unidentified Cylinder Detected B-21
0301 Cylinder 1 Misfire Detected B-22
0302 Cylinder 2 Misfire Detected B-22
0303 Cylinder 3 Misfire Detected B-22
0304 Cylinder 4 Misfire Detected B-22
0325 Knock Sensor 1 Circuit no Signal C-27
0335 Crankshaft Sensor Incorrect Signal C-06
0335 Crankshaft Sensor Open Circuit C-06
0340 Camshaft Position Sensor Circuit No Signal C-13
0340 Camshaft Sensor Incorrect Signal C-13
0351 Ignition Coil 1 High Input B-23
0351 Ignition Coil 1 Incorrect Signal B-23
0352 Ignition Coil 2 High Input B-23
0352 Ignition Coil 2 Incorrect Signal B-23
0353 Ignition Coil 3 High Input B-23
0353 Ignition Coil 3 Incorrect Signal B-23
0354 Ignition Coil 4 High Input B-23
0354 Ignition Coil 4 Incorrect Signal B-23
0420 Catalyst Efficiency Above Threshold C-31
0443 Evaporative emission control system purge control valve circuit shorted C-28
0443 Evaporative emission control system purge control valve circuit shorted -C28
0443 Evaporative emission control system purge control valve circuit open C-28
0460 Fuel Level Sensor Circuit High Input C-14
0460 Fuel Level Sensor Circuit Low Input C-14
0460 Purge flow sensor circuit malfunction C-14
0500 Vehicle speed sensor malfunction B-10
0530 A/C Refrigerant Pressure Sensor Circuit High Input Air Conditioning System B-05
0530 A/C Refrigerant Pressure Sensor Circuit Open Air Conditioning System B-05
0560 System Voltage High Input C-04
0560 System Voltage Low Input C-04
0565 Cruise Control SET and RESUME active C-17
0566 Cruise Control Off Signal Circuit no or Incorrect Signal C-17
0567 Cruise Control Resume Signal High Input C-17
0568 Cruise Control Set Signal Circuit High Input C-17
0571 Brake Switch Circuit Low Input C-15
0602 Powertrain Control Module Not Programmed C-02
0602 Security Code Not Programmed C-02
0602 Vehicle Identification Number Not Programmed C-02
0602 Variant-Coding Not Programmed C-02
0606 Control Unit Re-Initialisation C-02
0650 Malfunction Indicator (MI) Control Circuit High C-36
0650 Malfunction Indicator (MI) Control Circuit Open C-36
0700 EOBD Error stored by Transmission Control (TC) Modul B-06
0700 MIL request from Transmission Control (TC) Modul B-06
0704 Clutch Switch Input Circuit High Input C-16
1110 Variable Intake Manifold Signal High C-33
1110 Variable Intake Manifold Signal Low C-33
1110 Variable Intake Manifold Open Circuit C-33
1120 Accelerator Pedal Position Sensor 1 High Input C-08
1120 Accelerator Pedal Position Sensor 1 Low Input C-08
1120 Accelerator Pedal Position Sensor 1-2 Correlation C-08
1122 Accelerator Pedal Position Sensor 2 High Input C-08
1122 Accelerator Pedal Position Sensor 2 Low Input C-08
1130 O2 Sensor 1 Signal Out of Range C-30
1130 O2 Sensor 1 Signal no Activity detected C-30
1130 O2 Sensor 1 Signal Switching Time Error C-30
1170 System too rich (Bank 1) C-30
1170 System too lean (Bank 1) C-30
1230 Main Relay Circuit Voltage High C-03
1230 Main Relay Open Circuit C-03
1326 Knock Control Maximum Spark Limit Cylinder 1 C-27
1327 Knock Control Maximum Spark Limit Cylinder 2 C-27
1328 Knock Control Maximum Spark Limit Cylinder 3 C-27
1329 Knock Control Maximum Spark Limit Cylinder 4 C-27
1372 Crankshaft Sensor Segment Error C-06
1372 Crankshaft Sensor Adaption Error C-06
1481 Fan Relay 1 Circuit High C-34
1481 Fan Relay 1 Signal Low / Open Circuit C-34
1482 Fan Relay 2 Circuit High C-34
1482 Fan Relay 2 Signal Low / Open Circuit C-34
1500 Electronic Throttle Control Motor Failure C-09
1520 Powerstage Currentless C-02
1525 Limp Home Position Error C-09
1526 Throttle Position Adaption Error C-09
1526 Throttle Position no Adaption C-09
1526 Limp Home Adaption Error C-09
1526 Lower Limit Adaption Error C-09
1530 A/C Relay Voltage High Air Conditioning System B-10
1530 A/C Relay Circuit Open Air Conditioning System B-10
1540 Air Conditioning Pressure Invalid Signal Air Conditioning System B-10
1540 Air Conditioning Pressure Signal High Input Air Conditioning System B-05
1540 Air Conditioning Pressure Signal Low Input Air Conditioning System B-10
1540 Air Conditioning Pressure Open Circuit Air Conditioning System B-05
1550 Electronic Throttle Control Reduced Power C-09
1550 Electronic Throttle Control Forced Idle C-09
1550 Electronic Throttle Control Power Management C-09
1550 Electronic Throttle Control Engine Stop C-09
1551 Engine Torque Always Higher Than Expected C-02
1555 Throttle Position Sensor (TPS) Load Signal not Plausible with Engine C-09
1600 Reprogram or Replace Electronic Control Unit (ECU) C-02
1606 Replace Electronic Control Unit (ECU) C-02
1610 Security Code Not Programmed Immobiliser B-07
1611 Wrong Security Code Entered Immobiliser C-02
1612 Immobiliser No Or Wrong Signal Immobiliser C-05
1613 Immobiliser No Or Wrong Signal Immobiliser C-05
1614 Wrong Security Code received Immobiliser C-06
1615 Wrong Vehicle ID from Body Control Module C-40
1616 Wrong Vehicle ID from Instrument Control Module C-40
1650 Service Vehicle Soon Light Voltage High C-37
1650 Service Vehicle Soon Light Voltage Low C-37
1700 SVS request via CAN B-06
2100 CAN-BUS Malfunction C-05
2101 CAN-BUS Maximum Configuration List not Programmed C-05
2104 CAN-BUS reset counter overrun C-05
2106 CAN-BUS no Communication with TCM B-05
2108 CAN-BUS no Communication with ABS/TC B-08
Passionford Addict
its serviced more than it ever needs to be considering what it is and the last time it had a management problem that wasnt the light that came on and it turned out to be a plug lead.
