Comparison between Eonon D2205 and Non-brand unit
Why Eonon car DVD players can get your money’s worth? There’re thousands of car DVD players in the market, some of them are without brand and very similar to each other. We can hardly discover their differences if only based on the beautiful words and photos. But we would like to do this for you, since Eonon is so confident and proud of our decent products, through this detailed comparison, you can easily find real truth behind. Hope it really helps you to make wise choice.
1. Appearance
Looking from a distance, we can see there is no notable difference between Eonon D2205 and the non-brand item. They’re both standard 2 Din units with 6.95 inch screen.
Eonon
Non-brand unit
2. Package:
It’s known to all that the package during delivery process is very important, especially, order online. Since any human factor or natural factor will easily cause the damage of the item inside.
Eonon
Non-brand unit
Eonon:
Eonon D2205 is well packed with thick customized foam. What’s more, there is a special white box to pack the accessories. It makes the whole package to be cleaner and nicer. At the same time, help avoid the possible crash between main unit and accessories.
Non-brand unit:
There is no special white box for accessories, they are packing together which will lead to scratch.
Let’s take a further look for the thickness of the color box:
Eonon
Non-brand unit
The thickness of Eonon color box is 2.24mm. While the non brand one is just 1.21mm which will easily get distorted.
3. UI(User Interface)
Most consumers will pay very much attention to the UI, since it represents the character of the unit and largely affect the user experience.
Eonon
D2205 has black and white menu UI, which looks very clean and elegant. We have a more humanization design, the most frequently used icons are enlarged to make your operation to be easier.
Enter to the system setting, you will find a intuitive menu listed in a graphical manner. You can easily set it up even without instruction in the manual.
Non-brand unit
The icons are listed simply without order, and the colors are not well matched with each other. It may easily get dazzled and put your safety at risk when driving at night.
Entering the menu, you will find it simply shows the basic setup icons. It is quite plain and in bad display due to the low resolution of the screen.
4. Assembly technology
-Cables
Eonon
Non-brand unit
Eonon:
Detach the panel, you will find a very clean and professional assembled internal structure in Eonon D2205.
Non-brand unit:
The cables are not in good order, looks a bit messy.
-Tuner Module
Eonon
Non-brand unit
Eonon:
There is a screening cover to protect the radio tuner module in Eonon D2205, That’s why the radio signal of D2205 is so great.
Non-brand unit:
With no screening cover, the signal will get interfered. However, it’s a good way to save product cost.
- Wire Connection
Eonon
Non-brand unit
Do you want to see more? Here is the full article:
http://www.eonon.com/eononCompareShow.aspx?cid=11
:PYour comments are welcome~! :P
1. Appearance
Eonon
Non-brand unit
2. Package:
Eonon
Non-brand unit
Eonon:
Non-brand unit:
Eonon
Non-brand unit
Eonon
Non-brand unit
-Cables
Eonon
Non-brand unit
Eonon:
Non-brand unit:
-Tuner Module
Eonon
Non-brand unit
Eonon:
Non-brand unit:
- Wire Connection
Eonon
Non-brand unit
Steve Escos
01-10-2015 06:57 AM
