fuel system swirl pots an pumps??
ZETEC TURBO
lookin into gettin a swirl pot an just wanna know what pump would be best to use to fill the swirl pot an would you run a filter before an after the swirl pot ? will be looking to use all aeroquip with the set up
thanks G
thanks G
i just used the original in tank one. but i think its supposed to be a facet sorta thing, just to lift it into the swirl pot.
i ran a filter after the swirl pot.
I'm using the in tank HP pump to fill the swirl pot, which has an open return to the main tank. Will also have a filter between the swirl pot and the new external HP pump
JK12
33
26-04-2021 12:09 PM
