efi block
Old Jan 31, 2011 | 08:38 AM
Andy Tucker's Avatar
Andy Tucker
Welsh And Proud
Default efi block
would like to do a efi conversion on a s2 rst.now i have done some research and as far as i can tell.
i will need a fiesta rs turbo block due to the cps and a efi manifold.
i would just to know: is this this true?
do i need some sort of adaptor plate/s?
how would i go about the loom?
and is it a hard job to do?
Old Jan 31, 2011 | 08:58 AM
chaffe's Avatar
chaffe
Turbocharging Technician
yes you need either a hole machined in your block, a fiesta block or a seperate 36-1 toothed wheel and a pick up. It is not a "hard job" if you are familiar with engine management and wiring diagrams. You need a fiesta loom if thats what you mean by going about it?
Old Jan 31, 2011 | 10:30 AM
Andy Tucker
Welsh And Proud
im not quite familiar in the old wiring department.i will be keeping my eye out for a frst block and loom then.but what about putting the mfi head back on and and fitting the efi manifold and injector rail.would i need to use some sort of adaptor plate or does it bolt straight on to the mfi head?
andy
Old Jan 31, 2011 | 10:34 AM
chaffe's Avatar
chaffe
andy
get an efi head too, but if you need an efi head and block then you be aswell putting a whole 1.8 zetec in, or a zvh at least, lots more GOOD zetecs out there, cheaper and more available than CVHs, in much better condition too 9 times out of ten
Old Jan 31, 2011 | 10:45 AM
Andy Tucker
Welsh And Proud
tbh mate i quite the efi.but s for needing the head to i might aswell go the whole hog and just buy a frst engine,ecu and loom.i asked a qusetion on here the other day in regards to the fueling situation.would i need to do an external swirl pot in the bood or would i be ok to just link the fuel pipes into the efi rail
andy
Old Jan 31, 2011 | 10:55 AM
chaffe's Avatar
chaffe
just put the pipes from the k-jet (flow and return) onto the rail. they have a swirl pot in tank already
Old Jan 31, 2011 | 11:10 AM
Andy Tucker
Welsh And Proud
just what i wanted to here mate.many thanks
Old Jan 31, 2011 | 11:13 AM
chaffe's Avatar
chaffe
no probs, all the vest mate
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
