nightmare
Old Jan 30, 2011 | 05:00 PM
Andy Tucker's Avatar
Andy Tucker
Welsh And Proud
Default nightmare
where do i start,ill give the short story
bought a mk2 xr2.sripped it and it was so full of rust the titanic laughed at me
so im going to be buying a s2 escort rs turbo and i dont like the mfi so i will be or i will pay someone to do it for me.
no then,i have read on the rs bible that you can just bolt the frst head and inlet onto the block and then need to fit the crank position sensor on the block and flywheel to run on efi(would pay someone to do that.
just 1 more thing,the fuel.am i right in thinking i will ned to use a external swirlpot and pump for this set up.
andy
Old Jan 30, 2011 | 05:10 PM
vaughant's Avatar
vaughant
I THINK (?????) that the heads are identical etc and you just need to drill/mount a crank sensor somewhere near the gearbox,of course you need the flywheel from an efi so the sensor can read the holes in the fly to run the car.
Fuel pump wise I'm not sure you need to worry to much about the existing set up as the mfi boosts fuel pressure via an accumulator so theoretically you should be ok just using the original mfi pump to power the efi system as efi runs on lower pressures than mfi.
Old Jan 30, 2011 | 05:14 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
This made me lol mate!
Old Jan 30, 2011 | 05:19 PM
Andy Tucker
Welsh And Proud
it was mate.put the grinder on the wing and almot lost an arm
Old Jan 30, 2011 | 05:21 PM
Andy Tucker
Welsh And Proud
vaughant.thanks alot mate.where about are u in swansea mate
Old Jan 30, 2011 | 05:23 PM
dave_s2_rst's Avatar
dave_s2_rst
dont forget you need an efi flywheel.
do a search under the rs section (plus there is a guide there to)
Old Jan 30, 2011 | 05:25 PM
Andy Tucker
Welsh And Proud
juts copied the parts list from the rs bible
A list of parts required for Converting a S2 ERST to EFi, using the XR3i Loom method:
OFAC Fiesta turbo ECU. (OFAB can be used but takes a little bit more work, and will be discussed a bit later)
Ecu related MAP sensor. (OFAC ecu will need an OFAC MAP sensor)
Fiesta turbo engine, or mixture of adapter plates and a trigger for the CPS.
EFi inlet manifold, throttle body and charge carrier
ACT sensor, from the fiesta turbo
Throttle body to charge carrier pipe, still available from Ford at the moment!
EFi flywheel, Fiesta RS, XR2i, XR3i (EFi)
XR3i EFi whole loom
XR3i Throttle cable and pedal
EDIS Module and coil pack etc from XR3i (or Fiesta RS)
where's my flexible friend gone.
Kyle Langford
27
Aug 5, 2019 07:54 PM
pabloXR
Sep 21, 2015 12:42 PM
JamesH
Sep 2, 2015 10:02 AM
Mark 3D
Apr 11, 2005 08:49 AM
Redeye Jedi
Mar 14, 2005 09:20 AM
