Elec problem
Old Jan 24, 2011 | 01:11 PM
BIL N KEL's Avatar
BIL N KEL
Default Elec problem
I've recently reshelled my saff and while checking everything over ready for mot I have found that I can't get the headlights to work on dip or main beam but I have side lights. I can flash the headlights using the indicator stalk. Also I don't know if it's related but the windowscreen washers and horn doesn't work either. I'm thinking maybe light/wiper stalk or an earth. Does anyone know where all the earths are for the headlights. Any help is much appreciated
Thanks Billy
Old Jan 24, 2011 | 01:13 PM
BIL N KEL's Avatar
BIL N KEL
On saff cossie
Old Jan 24, 2011 | 01:29 PM
martysmartie's Avatar
martysmartie
It sounds like the stalk as it works with the flasher so clearly the connections are ok, bypass the switch as a test there is a relay for the dip/main, the earths are behind the headlights themselves on the bodywork.
The horn and washers are completely different circuits, the horn again has a relay and is fuse number 13 or 14 IIRC (30A)
Martin
Old Jan 24, 2011 | 01:39 PM
BIL N KEL's Avatar
BIL N KEL
Cheers martin i thought they were the only earths for headlights and they are ok. If they flash then surely they are earthed ok. Do you know which relay is the dip/main
Thanks Billy
Old Jan 24, 2011 | 04:14 PM
martysmartie
Again if it flashes the relay must be ok, for the main beam at least, I would check the switch first. I can give you the relay number, IIRC it's a black one?
Martin
Old Jan 24, 2011 | 05:21 PM
BIL N KEL's Avatar
BIL N KEL
Sorted now I removed the stalk and give a good spray with some wd40 and worked the stalks up and down, refitted and they work now. Must not have liked sitting about for 6 months not being used. Cheers for the help mate
Old Jan 24, 2011 | 06:02 PM
martysmartie
No problem, glad I could help.
Martin
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
