Steering wheel removal
You remove the center and undo the nut underneath, however you will need to remove the airbag in the process, so FIRSTLY disconnect the battery and wait 10 minutes for the airbag to discharge, having one of these deploy in your hands is not something you would want to happen!
Martin
Martin
guessing you have an air bag there is two small holes on the back side of the wheel that will be a torx or a small bolt heads once un done then undo the main bolt but leave bolt in lose and pull on the steering wheel then remove make sure you have your wheels straight and you do not turn the clock spring under it as it will brake and you will have no horn and airbag
what are you trying to do
Martin
Martin
I can't find any screws on the back can only find clips on the airbag cover it's really annoying me I am trying too change too a puma leather wheel on cause mine is horrible grey and scabby doesn't look nice trying top get it looking good for ford fair
I think it's a myth waiting for a period of time after the battery is disconnected to remove the airbag. Once the power is off, it's off.
The other steering wheel will fit, if the spline is the same.
A pair of torx bolts or similar live inside these holes - you push your bit into the hole till it engages with the bolt, and then you unscrew.
As for the airbag, my mechanic chum told me that if the ignition was off there was no power to the airbag so disconnecting the battery wouldn't change anything which makes sense.
I still undid the battery and waited though, just in case. It cost nothing to do that, but could have been expensive if he was wrong!
I heard a story when I worked in BMW dealer of a bloke changing airbag module on an E46 cabrio, as he plugged the module in the whole lot of airbags went off,side curtains the lot..
Needless to say he shat himself.
JoeyBoyden
04-01-2024 02:36 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
