Removing saph turbo...??
±§~Quadzackular~§±
Hello,
Well as you might know im new to engines as such and i wanted to remove my turbo...
I have took off the 3 bolts on the exhaust bit BUT the 4 bolts on the bottom on the turbo look a cunt...
Should i try my best and remove these or is it best to try and remove all 60,000 bolts on the manifold then take it all out and remove the turbo?
If it helps its a 4x4 and the engine is in the car so i cant get around properly.
Many Thanks Eigdoog.
Monte 087
It's a bit of a pig to do but it is possible to do without taking the manifold off personally I think its harder to get the manifold off than the turbo istelf, always manage with a 17mm stubby spanner.
±§~Quadzackular~§±
So ill have to bust my knuckles what ever way i do it, Well i didnt want to take the manifold off but if it was 100% easier i would of. So ill just get a sledge hammer out and keep hitting it till it comes off, About 7 hits?
![Bat](https://passionford.com/forum/images/smilies/pascontent.gif)
Zee Germans are coming
±§~Quadzackular~§±
Was going to put WD40 on it today and do it tomorrow and forgot!! Not at home tonight either! Looks like it will be a sledge now
Cheers for the help guys!
You talking about the four bolts with the 12 point heads facing downwards? I jack up the car, loosen the engine mount, jack up the engine and use a long extension bar from underneath lying on the floor. Horrible fucking job.
Charlie
Charlie
±§~Quadzackular~§±
That really works?![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
Im just gunna try from the top as i hate getting under it when i jack it up lol
not a noticable amount to look at but works a treat
also put some wd40 on before you start
it wont take long to penetrate
and if they are really super tight try tightening them a bit more being very careful and that might help to crack them off
but yeh really heat the bolt around the manifold
Monte 087
He is on about the 4wd manifold bud, the 2wd one is a piece of piss in comparison IMO.
±§~Quadzackular~§±
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Just the 6/8/12 star or whatever they are (10mm socket) all done.
I did think the only difference was the snail positioning though,slacken and spin ?.
ive recently done this on mine, but cant remember exactly how i did it but it is possible without cutting any spanners. drop the alternater and oil return from the turbo and it gives you a bit more room if i remember correctly! it just seems that you dont seem to be getting anywhere fast but you get there in the end.
±§~Quadzackular~§±
So i gave it ago today, I got the two bolts off (away from the engine) easy as anything BUT i cant get the other two on the near side to the engine...
Also i have snapped a spanner in trying
±§~Quadzackular~§±
So it took me something like 2 days to find out that taking the turbo off alone is a bad idea and the manifold is REALLY easy to take off, It took me less than an hour to remove as 5-8 of the bolts were lose...
The gaskets on the manifold are i think fucked as two are spilt into two bits now.
I have broke 3 spanners and smashed some glass bent a ratchet (so it broke the glass)
![](http://i837.photobucket.com/albums/zz292/Eigdoog/Sierra%20Sapphire%20Cosworth/f3e8a8c5.jpg)
How it looks now![Content](https://passionford.com/forum/images/smilies/content.gif)
![](http://i837.photobucket.com/albums/zz292/Eigdoog/Sierra%20Sapphire%20Cosworth/8f754138-1.jpg)
The red is the one that i just could not get to as every spanner is to big.
The blue one would have made like easy but the bolt is now round... so a spanner wont work![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Thanks for all your help guys![Top](https://passionford.com/forum/images/smilies/smile011.gif)
How it looks now
±§~Quadzackular~§±
Russ Payne
25-09-2015 08:29 PM
Fudgey
17-09-2015 01:06 PM
