Bypass PATS Immobiliser Mk5 Rs2000
pats
are far as im aware there isnt a pats system on the mk5 rs2k, just mk6.
whats up with the car itself?
there is an alarm system usualy fitted in the drivers footwell just behind the kick panel closest to the doors, the plug on that sometimes comes loose which stops the car starting, can also pull the plug off and bridge to of wires to remove it completely,
RS2000 Conversion
Yeah the Mk5's have an external PATS module hidden behind the glovebox.
Apparently the is a way to bypass it in the loom? As i dont have the the chipped keys
Theres nothing wrong with the car. I will eventually be doing a conversion. I will be using a Mk6 RS loom. So i need to adapt that to fit a Mk5 ECU
massivewangers
30
01-10-2015 07:40 PM
