X5 3.0D HELP (carlo) Update Fixed...
hi, Strange x5 problem my mate had just done a 300 mile run in it came home with no problems . went back to it a hour latter took longer than normal to start he drove 200 yards down the road and it started pouring smoke out and the revs riseing on its own so he pulled over turn the key off and it carried on running for about 20 seconds any ideas??
thanks deany
UPDATE
Hi i took turbo hosesto check for play in shaft to find it was perfect with a lot off oil in there, So next the oil was dropped from the sump and there was 6 gallon of oil and fuel mixed .
and ideas fuel pump??? oil cooler?? injector seal??
thanks deany
UPDATE
There is a oil seperator / breather on the rocker cover best change that as well we have seen small back street garages change the turbo's because the above fault as well & its not sorted the problem its been that breather blocked. But without seeing the car its hard to say whats the mileage ? mine has done 83k & im just waiting on the turbo goin
Turbo's at a dealer like here are about Ł1200 + vat mate just for the part you can get them out there for nearly half that ! try euro car parts or such likes ! its not a dealer only job either any decent garage will be able to do it & they might have their own supplier of turbos as well its worth shopping around. With a bmw turbo you get a 2 year warranty other suppliers normally a 1 year. Keep me posted on how you get on.
UPDATE
just re read it, did not notice the diesel in oil, yes i would agree with carlo on this one
Yeah mate the oil was changed about a week befor and it got 7 litters put in then when drained off last night there was about 25 litters lol.
Fill it back up with cheap oil mate remove the engine cover take all the spill pipes off try to start the car ! as i said above they all should trickle out the holes but if a injector is duff it will spout out. injectors are a hard thing to diagnose on them esp if its that fucked trying to do a smoothe running test etc will be hard.
Hi, just a update to say it is fixed was the seal on the front of fuel pump,was pumping fule stright in to timeing chain cover..
thanks everyone for the help.
TPM961
15-01-2018 10:50 AM
