are british tuners living in the past
Old 02-01-2011 | 10:19 PM
  #41
rog's Avatar
rog
Fit for purpose, no point in changing the management etc if it will do what you want it to IMO, eryone is different i guess but i don't see the point in changing something that is perfectly useable and adaptable to most specs.
Old 02-01-2011 | 10:20 PM
  #42
Chip's Avatar
Chip
*** Sierra RS Custard ***
Will, I think that the way that people who dont really understand engines tend to apply logic to things like CR or port size or turbo size or runner length is always the same:
I know adding a little is considered good...
So adding a lot must be great...
and adding far far too much should be perfect for my application!
The phrase "bell curve" doesnt seem to be one they understand!
Old 02-01-2011 | 10:21 PM
  #43
caprizetec170's Avatar
caprizetec170
Originally Posted by Will Pedley
At 11:1 CR you must be planning on running it on Toulene fuel a la 80's F1 cars
To give you an idea, I worked for an evo tuning company and we used to build 2.4 stroker engines that revved to 9000rpm with 9.0:1 static compression ratio. With a Turbonetics Y2K turbo one of those engines made 930bhp at the flywheel (calculated) about 7 years ago on methanol. That was running 8 x 1600cc injectors at over 80% duty cycle.
thanks for reply will but 930bhp 7 years ago was a hell of an achievment feck me thats a lot of fuel
Old 02-01-2011 | 10:25 PM
  #44
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Yeah, Evo's are 'thirsty' engines in comparison to YB's anyway!
There is so much technology out there currently to aid in the design of engines etc. The future is going to be phenomenal for the tuning scene!
I'm in my second year of my degree now and we're spending approximately 50% of our course time for the next 2 years using a package from Gamma Technologies.
Some of the simulations you can run are truly phenomenal, i've even built base fuel maps for aftermarket ECUs through calculations i've done with the software and it's been sensibly close!
http://www.gtisoft.com/applications/...erformance.php
  #45
caprizetec170
Ah i know a bit chip. and know i dont know what a bell curve is is it similer to a bell end
Old 02-01-2011 | 10:26 PM
  #46
bigchez's Avatar
bigchez
Was that the yellow RC car? Saw it at one of the Donno Xmas track days, looked mental!
Old 02-01-2011 | 10:30 PM
  #47
Big Will_'s Avatar
Big Will_
No mate, 930bhp was the 'old' white RC demo car. Nicknamed 'Bessy'
The yellow one was the one I played a part in building. We did everything we could to take weight out of that car, even down to removing the middle skin of the car!
The yellow one ran a GT42R with a 1.06 back end at around 2.5-3.0bar of boost on methanol. But yes, in summary - 850+ bhp in an 1100kg car = pokey
Old 02-01-2011 | 10:38 PM
  #48
Chip's Avatar
Chip
Similar in that they are both named after a bastardised representation of the shape of a traditional church bell originally, but thats about the only thing that springs to mind.
That sort of shape, ie as you start increasing a value for something like CR, it gives you more power then more power then more power, then starts getting less and less and less.
Ie there is an optimum value, and more than it is just as damaging as less than it.
Old 02-01-2011 | 10:44 PM
  #49
gjh's Avatar
gjh
Originally Posted by MadRod
Ever been in a 750bhp EVO it would redefine the meaning of shite for you cos it would be all over the seat. Light years ahead of any Cosworth simply light years .
C'mon now Rod you ain't getting a 750bhp evo for Ł5k no matter how hard you try. I could have said an enzo is light years ahead, your talking about a completely different level here. I think I'll agree with Glenn and keep the ford blinkers on for a Ł5k car a cossie would be my choice, besides, I bet a 750bhp escort cos would be in with a chance.
Old 02-01-2011 | 11:01 PM
  #50
rs_turbo_tony's Avatar
rs_turbo_tony
Originally Posted by zetec-Sam
Talk about working backwards!
zetec sam backwards
Old 02-01-2011 | 11:03 PM
  #51
rs_turbo_tony
when you look at swedes and other over seas tuning companys i can see where your coming from in the terms bhp and torque figures .
Old 02-01-2011 | 11:26 PM
  #52
hogdog's Avatar
hogdog
People make the assumption that Americans are into their supercharged V8's...some are but they are also at the forefront of tuning the Zetec. I've seen stuff on their cars that I've never seen over here and the development is relentless.
The YB is older than me and I'm falling apart at the seems, if we're stuck in the past it's probably because alot of our tuners only tune a seriously old engine with the restrictive mindset that nothing else is quite the same.
I agree with the O.P's suggestion, we're a long way behind but the new FRS has got British tuners working hard.
Old 02-01-2011 | 11:43 PM
  #53
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
So they say lol id have said julian godfrey and mark sheed make the best numbers and there bhp and torque is there at low revs and stays right till the end
Old 02-01-2011 | 11:56 PM
  #54
cbp's Avatar
cbp
Jenspeed that has done most of the really powerful YB's in Norway for the last decade is working closely with Julian Godfrey and has done so for a really long time. So i do not think it's fair to say that the UK tuners live in the past. Almost every high power YB in Norway, Sweden and England run more or less the same kind of parts. 300-400 bhp cars over here normally uses remapped standard cossie ecus and T34's.... so can't really see the difference there either
Everything is down to what the customers want and how much they are willing to spend..
Old 03-01-2011 | 12:00 AM
  #55
Chip's Avatar
Chip
Indeed, if there is a difference at all between the uk and other countries with regards to YB tuning I think its more that people in the UK generally have a lot less money to spend on their car than the sort of swedish cars etc that we see evidence of over here via mags and forums etc.
Old 03-01-2011 | 12:08 AM
  #56
cbp's Avatar
cbp
Well... the cars you see in mags are only a few.... not all of them are like that
So the difference is really not that great actually. There are ALOT of cossies over here that is seen a year or two before beeing sold on because breaking down or beeing to expensive for the owners Not a lot of cossies that are prepared like the Reyland Escort for example and perform on a high level year after year...
Old 03-01-2011 | 12:28 AM
  #57
Chip's Avatar
Chip
cbp, exactly there is no reason for us to hear about all the 400bhp and below cossies in norway or sweden etc, as its not interesting enough for mags to report on when they can find the same thing so easily at home.
so its not just about a real difference, its merely a perceived one, although I suspect just in terms of the fact that the cars are so much more common over here that there are more of them over here in a lower state of tune as a result. I suspect the base cars are cheaper here too.
Whats a 1992 4wd saph worth other there? Over here it would be about 6K euros or so, and a ropey 2wd is more like 3K euros.
Old 03-01-2011 | 12:29 AM
  #58
rs_turbo_tony
My mates saphire cosworth pulled 0-60 in 3.8 a couple of years ago and had a problem with dumpvalve 2010 ford fair running half the boost still pulled a 4.4 0-60 i dont now wot bhp its running but to pull times like that its a acheivement and a half
Old 03-01-2011 | 12:34 AM
  #59
cbp's Avatar
cbp
There are not that many for sale these days actually.... there is one atm on Norways biggest sale site... and the asking price is 15500 euros it looks like it is in good condition though
Old 03-01-2011 | 12:36 AM
  #60
Chip's Avatar
Chip
Would need to be conours and come with a glovebox full of cocaine to fetch that much money over here mate
So I think by definition its safe to say the average person with a cosworth over there is owning it on a bigger budget than the average owner here (although there will of course be lots of exceptions, im just generalising)
Old 03-01-2011 | 12:38 AM
  #61
Sonic Boom's Avatar
Sonic Boom
Pauls?
Rich
Old 03-01-2011 | 12:39 AM
  #62
Sonic Boom's Avatar
Sonic Boom
Christ! What are 3 Doors fetching?
Rich
Old 03-01-2011 | 12:40 AM
  #63
Chip's Avatar
Chip
The timing gear there is intended for a bit of fun between mates etc, rather than to be a particuarly accurate representation as far as im aware, I dont believe its safe to assume its genuinely representative of the exact figures.
Old 03-01-2011 | 12:46 AM
  #64
cbp's Avatar
cbp
Well it's not entirely true what you are assuming. The reason for this is, the people with lots of cash to spend on their cars are not driving cossies anymore.. they are driving evos, supras, skyline s and so on...
The cossie is the "poor" mans supercar, at least the Sapphires are. So much of it is done on the cheap as the cars are often driven by youngsters with a harder right foot than they have a big wallet..... Escos and whaletail cossies are proper expensive and fetch over 20000 pounds....... yikes...
Old 03-01-2011 | 12:47 AM
  #65
Chip's Avatar
Chip
Thats all the same over here too, just the whole budget in general is shifted downwards as we are poorer than you
  #66
Sonic Boom's Avatar
Sonic Boom
Right then i'm off to Norway to sell my 3 Door
Rich
Old 03-01-2011 | 01:17 AM
  #67
vaughant's Avatar
vaughant
Tbh Britain is always at the forefront of any design and engineering breakthroughs.as pointed out above there's all sorts of reasons that tuners follow the routes that they do.if it was a lottery win jobbie and you could tell the tuner to just spend whatever on a car then I see no reason why British tuners couldn't get the same bhp out of an engine that any other countries tuners could.
Old 03-01-2011 | 01:47 AM
  #68
RWD_cossie_wil's Avatar
RWD_cossie_wil
Making the peak BHP is the easy bit, most people with half a clue could build a 500bhp yb now just by chucking the right bits at it. The difficult part is making it reliable, responsive & drivable with a large power band.
Old 03-01-2011 | 02:07 AM
  #69
rs_turbo_tony
Originally Posted by Sonic Boom
Pauls?
Rich
yes mate hows ur 3 dr doing
Old 03-01-2011 | 02:11 AM
  #70
rs_turbo_tony
my point is regardless of tuner behind times some of these cars with ybs put down some really good times and track cars even better built by tuners for them selves
Old 03-01-2011 | 03:45 AM
  #71
HockeyNomad's Avatar
HockeyNomad
In response to the origional question, I have seen loads of development on cossie engines using twin scroll GT turbo's, and making good numbers as a result,
The tuners are moving with the times, but customers may not be willing to pay the extra it costs,
plus the old "stages" are set in peoples minds and memories, and many will go from there when thinking about upgrading the power in theor YB.
Old 03-01-2011 | 08:53 AM
  #72
1 person wound up.
Old 03-01-2011 | 08:58 AM
  #73
Rod why dont you stop fooking about with that old sierea of yours and start playing with evos.Ok your sierra looks nice but will it ever got used more than doing just high speed runs?
Old 03-01-2011 | 10:32 AM
  #74
big_wig_074's Avatar
big_wig_074
got to love people watching gatebil videos, seeing the race spec 700 plus bhp monsters and thinking that they are in anyway related to a daily or weekend ROAD car!the guys with the big power cossies will be trailering the cars down and giving them a good pasting on track, while their road car is no doubt a nice e46 m3 or the like.
compare top spec track cars in both countries, Harveys escort, Martins escort, Norris Evo, it all compares nicely!
oh and if you think old school DOESNT work,get along to the RSOC day and watch the old Bailey MK2 escort obliterate everything on track with its old school setup!
a t34 std or slightly lower comp engine with 2 bar is a FANTASTIC car to drive on the ROAD.
Old 03-01-2011 | 11:46 AM
  #75
RWD_cossie_wil
The Bailey Escort was running a full Rs 500 Engine with T4 & 8 injectors last time I saw it?
Old 03-01-2011 | 12:05 PM
  #76
Chip's Avatar
Chip
Yes it is as far as im aware too, which very clearly is an example of "living in the past" and yet it still works VERY well
Old 03-01-2011 | 12:17 PM
  #77
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Too old mate my Saff will be my last performance car. Im not interested in driving an old Cossie around the Streets anymore that went 5/6 years ago. My only aim is to make my Cossie go as fast as possible & set a speed that will never be beaten. Dont really give a hoot what others think about that its a technical exercise that keeps my old brain working.
Old 03-01-2011 | 12:23 PM
  #78
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Yes similar to my Spec 10 years ago as an engine compared to similar Power cars today its terrible really terrible. It would be so much faster with a later Spec engine. A drive in Deanos car would convince you just how far a 550bhp conversion has come. Both have Power but one has grunt & the other dont. I know cos ive driven cars throughout that 10 years of development.
Old 03-01-2011 | 12:25 PM
  #79
Dlatch!'s Avatar
Dlatch!
why are people not turning to the duratec more for turbo applications?
lack of parts?
sure lots could be done with that engine but it seems to me the zetec is being pushed more in turbo applications and development.
The Bailey Escort is awesome remember seeing it at ford fair a few times ripping past everything on track and getting black flagged lots too
Old 03-01-2011 | 12:28 PM
  #80
gjh's Avatar
gjh
Set a speed that won't be beaten eh? I do recall Martin hadland mentioning in the 200mph issue of fast ford "it would be nice to do 220mph" or something along those lines, maybe he has a plan brewing...
