fuel hose size
02-01-2011 | 07:03 PM
fuel hose size
is -8 recommended from fuel tank to fuel pump on my 3dr?
02-01-2011 | 07:18 PM
on mine i have -10 tank to pump
half of the reasoning might be because the aeromotive pump im running is soo bloming big
02-01-2011 | 07:24 PM
ill be changing to a 044 pump if thats any help.
03-01-2011 | 10:50 AM
03-01-2011 | 10:55 AM
if i can remember im running 8mm braided from tank to engine if i can remember right on a 044 pump
03-01-2011 | 11:10 AM
03-01-2011 | 12:20 PM
-10 on my Saff iirc.
If you use a goodridge adaptor remember to drill the bore bigger as it steps down quite a lot.
03-01-2011 | 04:01 PM
Quote:
Originally Posted by
cozzy jeff
8mm I.D. ?
yea 8mm i.d
03-01-2011 | 04:26 PM
Dan@Rapid-Ford
dan was going to weld a -8 or -10 fitting to the tank and wandered which size most people use
04-01-2011 | 10:59 AM
Sorry phone would let me reply yesterday
-10 goes straight onto the orig outlet on the tank
04-01-2011 | 04:11 PM
cozzy jeff
anyone else?
Im running TWO -8 lines from my tank to TWO Bosch 044's
Hope that helps
04-01-2011 | 06:01 PM
measure the metal pipe off the tank today its 15mm i.d. i guess -10 would be better but struggling to find -10 teflon fittings
04-01-2011 | 07:00 PM
I'm running -8 (1/2" bore) from tank to 044 pump, then -6 (3/8" bore) from pump to rail.
04-01-2011 | 07:16 PM
that was going to be my first choice mate but using -8 teflon hose reduces the hose size down by 4mm does this matter?-8 would be the easy option as i would have no problem getting the hose and fittings.or i could just go with the original push on hose and just use -6 fittings for the return.
04-01-2011 | 07:21 PM
04-01-2011 | 07:33 PM
-10 it is then cheers guys.
05-01-2011 | 10:29 PM
Dan@Rapid-Ford
Ive Earls adaptors going into my pumps. They are incredibly small too, I drilled them out as much as possible.
I'm using -8 into the pumps
JK12
33
26-04-2021 01:09 PM
Cossiesteve
Ford Escort RS Cosworth
17-09-2015 01:37 PM
Mk5brown
09-09-2015 01:52 PM
hopper350
04-09-2015 01:53 AM
