is anyone running re circ closed valves
Plumbed from turbo elbow pipe to inlet,?
what is needed and where from or is it make it up as you go. I have a pic somewhere of one set up I will try and find it
That's a gen Rs500 set up, and you have sort of answered your own question. I am running one on my Escos, but have had to have my hoses specially made as there is zero space to do so.
I wondered if it was standard set up for RS500.. What valve are you using. this one will be going on GT30 with hard pipe from turbo to filter and swedish inlet?
what are benifits? and do you still get any noise of chatter or blow off. he does not want noise.
I'm using a very similar valve to the standard cossie one, but made more chunky in alloy. I got it off Ebay for Ł35, advertised as a VW part, but it makes no odds really as a valve is a valve. I am running it as my Escort is small turbo, so the air HAS to be recirculated to avoid fuelling issues. Noise wise, you can hear a small whoosh/ very slight "chatter", but far far less than an open to atmosphere valve. It is the best compromise if you want the protection of a D/V without the horrid noise.
Here you go, very similar to the one I am using:
http://cgi.ebay.co.uk/IMPREZA-WRX-GC...item3a6060ae24
im running a dump valve but still get the chatter aswel as the woosh sound but i want a recirc valve i was looking at the ggr one i had on my old escos as that still chattered like mad
[quote=RWD_cossie_wil;5267953]Here you go, very similar to the one I am using:
http://cgi.ebay.co.uk/IMPREZA-WRX-GC...e24[/quote]
Have you got any pics of your set up?
Red_bull
09-08-2015 08:34 AM
