Can anyone tell me the prob with this car....
Vinny
Is my cousins 1.4 T reg clio, the bubble shaped headlight version
it wont start, it turns nice and fast but just wont fire
*there is no spark
*he has had a new coil pack on it
*new crank postion sensor fitted
*and he has changed some sensor thats mounted on the gear box that tells it to spark or someting
but no luck
it was running fine then it wouldnt start, then it would be ok then now it wont start at all
any ideas ???
*there is no spark
but no luck
any ideas ???
is it now definately sparking well on all cylinders. check by taking the plugs out.
if they are and the gaps are fine then it could be a fueling problem.
Its the alarm system, they are prone for it!
My ex's had the same problem, i ended up sending off the alarm to someone to have it disabled, think it cost me around £70.
Google should help.
Gavin.
Google should help.
Gavin.
I used these people...
Mobiletuning
18 Rosedale
Spennymoor
Co Durham DL166SB
01388 815217
http://www.alarmremotes.co.uk/
Took a few days but it solved the problem. Most auto electricians either wont touch it or want £300+ to do the same job.
You will need to sort some kind of alarm out for your insurance though.
Gavin.
Edit... too late but never mind!
Mobiletuning
18 Rosedale
Spennymoor
Co Durham DL166SB
01388 815217
Gavin.
CabrioTurbo
01-08-2015 11:04 AM
